Username: Xpehbam China,
NC
Post Number: 72 Registered: Jun-05
Friday, February 29, 2008 - 18:51 GMT Hi! This is just me or everybody has freezing problem on NFUSION receivers? My receiver freezing almost every 20-30 min. Sometimes every 3 min.
Username: Bill038 Post Number: 509 Registered: Sep-06
Friday, February 29, 2008 - 19:13 GMT What bin do you have?
NC
Post Number: 73 Registered: Jun-05
Friday, February 29, 2008 - 19:21 GMT I think 1.44, the new one from couple days ago..But I have this problem for last couple weeks..And I am not sure why?
Username: Bill038 Post Number: 510 Registered: Sep-06
Friday, February 29, 2008 - 19:24 GMT Do you have the proxy server turned off. I installed it yesterday and have no problems, but I'm not using a proxy server either. I think you were supposed to do a reste before the install and one after.
NC
Post Number: 74 Registered: Jun-05
Friday, February 29, 2008 - 19:31 GMT Thank you! I will try that later today...I will posted..
Username: Bill038 Post Number: 511 Registered: Sep-06
Friday, February 29, 2008 - 19:36 GMT YW
Username: Saqeeb9000 Post Number: 2548 Registered: Oct-07
Friday, February 29, 2008 - 23:46 GMT VB .. freezing problems.. i know bin 1.44 have some freezing problem. but if you turned off proxy it works fine.. but you said u have this problem for couple of weeks now.. try to change epg to mannual instead of automatic..
NC
Post Number: 75 Registered: Jun-05
Sunday, March 02, 2008 - 14:42 GMT Thanks everybody! It's better now,I redownload everything, reboot, change epg to mannual, and now it's working much better (last night freeze only two times) Thank you..
