Bronze Member Username: UbbaPost Number: 100 Registered: Sep-06 | I did what everyone said and had the viewsat unfrozen then put in the new bin, but got no signals in any channel. So, did a factory reset and am now doing blind scan and have no channels being dowloaded as quality is 0. What can I do, please help? Thank you |
Gold Member Username: KirankumarKenya Post Number: 1840 Registered: Oct-07 | Lisa, post your settings so we can help |
Silver Member Username: MetallicaPost Number: 211 Registered: Jan-08 | did you reconnect your cables?? try to turn it off from the back than turn it back on...try that |
Silver Member Username: UbbaPost Number: 101 Registered: Sep-06 | My settings, I don't know if you mean the echo star. I download Echo star 3 and echo star 8.10. I tried everything. No channel is being downloaded. Have signal but no quality. Your help is so appreciated. |
Bronze Member Username: Your_mamaPost Number: 37 Registered: Sep-07 | You need to load the newest factory bin than the new vs bin |
Silver Member Username: UbbaPost Number: 102 Registered: Sep-06 | where can I find the new factory bin? |
Gold Member Username: KirankumarKenya Post Number: 1846 Registered: Oct-07 | Lisa go to menu>satellite and post the setings that you see there' like lnb type, frequency,switch type etc |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 438 Registered: Jan-08 | When load new bin the sat setup chang and you need to reconfigurate it, post youre sat setup and we help you Lisa |
Silver Member Username: LolPost Number: 404 Registered: Sep-06 | Lisa did you read the instructions ? Vs- Ultra only Before loading power off via rear switch and unhook satellite dish cable to allow receiver to properly boot up for USB Loading. After you have loaded file you may power off and hook up satellite dish cable .. Do it again |
Silver Member Username: UbbaPost Number: 103 Registered: Sep-06 | LNB Type: Standard LNB Frequency: 11250 as for TP Frequency it's different with each channel |
Gold Member Username: KirankumarKenya Post Number: 1847 Registered: Oct-07 | i need all the info for each satellite |
Silver Member Username: UbbaPost Number: 104 Registered: Sep-06 | Paul, I did all of these, mine is VS Ultra. Nothing worked so I did a factory reset as I was able to change channels, but everything was 0 in quality. |
Silver Member Username: UbbaPost Number: 106 Registered: Sep-06 | I only have 2 satellites and have echo star 3 and echo star 8.10. For each TP Frequ. it's a different number. I'm getting this info from someone who has the same info as the VS Ultra I have. Nothing is working. I have tried to add channels twice, but nothing has been added since Q is 00 all the time. Do I have to load a new factory bin and where do I get it? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 441 Registered: Jan-08 | Dont need to make factory reset this is the problem why you lost all setup but sometime the port change and motor setup with new bin |
Gold Member Username: KirankumarKenya Post Number: 1849 Registered: Oct-07 | if someone gave you the info then sort your problem out yourself GOOD LUCK Lisa Silver Member Username: Ubba Post Number: 106 Registered: Sep-06 Posted on Friday, February 29, 2008 - 10:08 pm: I only have 2 satellites and have echo star 3 and echo star 8.10. For each TP Frequ. it's a different number. I'm getting this info from someone who has the same info as the VS Ultra I have. Nothing is working. I have tried to add channels twice, but nothing has been added since Q is 00 all the time. Do I have to load a new factory bin and where do I get it? |
Silver Member Username: Ong_tuPost Number: 334 Registered: Jun-06 | Hey sand Nig*er if you can't answer the post get your dumb a*s off the site "retard" |
Gold Member Username: KirankumarKenya Post Number: 1850 Registered: Oct-07 | F@ck you you spamming azzhole |
Silver Member Username: UbbaPost Number: 107 Registered: Sep-06 | African, I appreciate your help, but don't need this childish behavior right now. If others are trying to help me, I truly appreciate that. So, anyone out there who is genuinely trying to give me advice, please help as I have no channels and don't know what to do? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 444 Registered: Jan-08 | Hi Ong_tu Gramma |
Silver Member Username: Ong_tuPost Number: 338 Registered: Jun-06 | Plymouth and the sand nig*er lol! Pathetic little kids lol! Watch your language sh*tmouth may be offended lol! |
Bronze Member Username: LuserPost Number: 83 Registered: Nov-07 | Most likely your antenna setting changed from a memory crash caused by this latest ecm. Go to antenna setup and scoll through each one even if its correct then change it then back keeping an eye on your quality and confirming the sat your on is the sat that displays when quality is good. Other than that its something like cable inadvertantly removed and replaced on wrong port or something like that. |
