Cs50$0 no info guide
Username: Boston410
After changing from bev to dn and changing settings that i really didnt know what i was doing, i get all the channels but no info guide it comes up when u hit guide on the remote but every channel says no info. Any ideas Thanks
Username: Dimwitt
Post Number: 444
date / time / timezone need to be correct.
epg info should populate if you go to a channel on 91W TP 12311, like 280 , 357.
--- OR channels 119 and 200 for dn
Username: Boston410
so just leave it on ch 119 or 200 and it should populate. Thanks i will try that
Username: Saqeeb9000
Mughe dard rehta hai, ..., Mujhe bhook ...
Post Number: 2589
Attached are channels for each DN/Bev sat you may use for complete EPG population.
EXTENDED EPG: Using any of these channels will give extended EPG data for any/all DN sats.
119w
ESPNA--145
WGN--239
FOXMW--418
CSNMA--424
FOXCN--427
FOXN--436
SNY--438
NHL--544
NHL--550
NHL--552
NHL--554
NHL--557
NBA--572
MLB--627
MLB--636
WGN--881
AUD19--946
SKDL--5802
EPSK1--5814
SIRI--6001
SIRI--6008
SIRI--6014
SIRI--6021
SIRI--6026
SIRI--6027
SIRI--6028
SIRI--6035
SIRI--6040
SIRI--6060
SIRI--6071
SIRI--6073
SIRI--6074
SIRI--6077
SIRI--6080
SIRI--6086'Regular' EPG
If you don't have 119w, the following are lists for each individual DN sat:
61.5w/148w
PLSAT--607
TVN24--609
RTPI--615
GEOTV--620
NBN--778Code:
110w
BIOGR--119
VH1CL--163
MLTRY--195
HBOLT--309
SHOCS--321
TMC-W--329
TMCXW--330
FRESH--499
TMC-W--898
TMCXW--899
129w
SPRKY--257
INFO--258
INFO9--259
SPRKY--5840
INFO--5841
INFO9--5842
WJET--7041
WSEE--7042
WICU--7043
WFXP--7044
WQLN--7047
WAHU--7932
D1000--9901Code:
105w
D105--7000Code:
121w
PLSAT--733
TVN24--734
KINO--737
RTVI--738
ALJAZ--761
MBC--766
118.8w
GEMNI--799
SURYA--800
D118--9903
These next two are for ExpressVu.
82w
FAIRM--716
FAIR--717
FAIRW--718
ABCHE--816Code:
91w
162 VuF2
167 VuF7
218 CHCH/Hamil
240 GLB/Edmont
280 NBC/Boston
296 UPN/Boston
352 Vu2
357 Vu7
410 The Score
510 BBC World
I hope this will clear up any uncertainty on which channels maybe used for best EPG population.
Note: Remember to add 1000 to the ExpressVu channel number if you use Bev channel renumbering.
