DEAD VIEWSAT PLAT/LITE
Username: Tigger_woods
2008 RESOLUTION, I WILL BE NI... VIP MEMBER
Post Number: 471
I finally have a fried fta unit, viewsat lite went dead yesterday.
Yes it went funny with the ecm yesterday, but was fine when I put new file in yesterday. On about 3 hours or so after downloading file and it just went dead, no noise or anything, just lost power.
You can hit switch on back until the cows come home but to no avail.
As a hoot I tried hooking up to null cable and loading factory, but hey, who`s kidding who, no power!
I took her apart checked connections, fuse is good, even as last resort put peice of foil around fuse to make 100% sure, but she is dead.
Even tapped gently all over unit, as any good backyard electrician would do, she`s dead.
Someone will surely say you have a clone, suppose it`s possible, but did check before using and it had all the ear marks of a original vs, plastic wrapping all around it, etc. and I got it from sky high electronics same as my other vs plat that never died. plus I have been using it for aprox 1 year, so I doubt it`s a clone. THINGS DO DIE!
This is my 5th FTA, so I guess it was my turn to have one die.
I used to jtag dish 2700 ird etc, so if anybody has a link to a jtag instruction for a vs plat lite, by all means let me know
Username: Metallica
Post Number: 221
Tiger..i don't think you can Jtag a Viewsat..LOL
i might be wrong but wait to see anybody have a better idea...
Good Luck..
Username: Quetoidalat
Post Number: 7
unplug cable disk
Username: Kirankumar
Kenya
Post Number: 1881
Tiger,
check something form me
turn receiver ON and at the back check if you can see a faint red light kind of U shape
Username: Tapeman
New York City in-HD, NY
Post Number: 2494
- Turn auto roll OFF
- Load latest BIN or any recent bin
- Make sure auto roll stays off after load bin
- Yo may have to enter keys manually
My VS Xtreme never went down like people reported
But also people reported LK's patches work too
Kenya
Post Number: 1883
King
he can't do anything,there is NO power,so we need to get power back
Username: Tapeman
Post Number: 2495
LK's patches:
https://www.ecoustics.com/electronics/forum/home-video/456107.html
However Nagra is using an old trick
a Simple Key roll
Username: Tapeman
Post Number: 2496
Oh my bad
Lost power
Yo may have to open receiver to check for fuse
Post Number: 472
Thanks for input by all
NO LIGHT OF ANY KIND.
no power at all, no red light.
YES I already took lid off, no sign of burned wires etc, fuse is good as I stated, even rolled it in foil for check.
Thanks I am open to suggestions.
Kenya
Post Number: 1884
Tiger,
NO promises but can you try this for me.
there are multiple wires coming from the power board to the main board,can you unplug it at the main board,also there are multi wires going from main board to front panel,unplug at main board.
after a minute plug them both in ,don't push too hard or you will crack the board.now see if there is any life in it.when you turn receiver On wait for a while don't keep turning it off and on.post results
Username: Tapeman
Post Number: 2497
Well T.W.
Power comes from power supply
And yo must damaged power transistor next to transformer
Assuming all other contacts are fine
All I can tell yo
VS extended their warrantee to 2 years
Yo may have to contact theit tech support for where to go
This is their link:
[link removed]
Username: Saqeeb9000
Post Number: 2567
tiger which website did u use to download new bins..
Username: Palau
Hercules, Coahuila Mexico
Post Number: 17
Hi There, I have a new VS Ultra and it went dead yesterday. I turn it off from back and it turns on but it then goes to 0 and nothing happens. Can`t use control. Any ideas?
Username: Metallica
Post Number: 222
Alfredo you need a new bin file VS is down yesterday...
PFTAUSW-080301U DN & Bev...
http://www.ftabins.net/forumdisplay.php?f=114
Username: Lklives
Post Number: 14113
If ya can get another one from a bud, U can try cloning em ..master to slave...otherwise U'll need a local repair shop or use viewsatusa.com , like KT stated..
Kenya
Post Number: 1885
Alfredo,
open your box and do this it will work
once all is ok,load factory bin 132 and then add latest bin,use cable cable for this NOT usb
Post Number: 473
Thanks to EVERYBODY!!! that responded, I had the hood off AGAIN like African suggested, I unhooked everything as he suggested etc and nothing was happening.
I then left it on while I started to take the front panel off, I took the 2 screws out and then began trying to take it off by pressing 2 spring hinges, as I was roughly trying to open it suddenly came on.
I guess we will have to give credit to AFRICAN now African dont let this go to your head, but YOU ARE PRETTY COOL
It works, 3 cheers to AFRICAN!!
thanks to EVERYBODY that responded, will redo my will and leave all possesions to African, my people will be in touch with your people.
QUESTION NOW IS, HOW LONG WILL IT LAST.
Kenya
Post Number: 1888
I am glad it worked out for you
enjoy
Username: Lklives
Post Number: 14115
Obviously U jarred something thats loose, had poor contact, etc..so its a hardware component issue..and will reappear..and I would definitely change out the fuse..
Post Number: 474
THANKS LK, ya it might have been something in front panel. We thanks everybody. New fuse for sure.
