Silver Member Username: Oleg1474Florida Usa Post Number: 951 Registered: Aug-06 | Well here we go again folks, Bev is partially down and DN will be soon to follow expect both to be all down by 5pm EST today. Not to sure what they are up to yet, but I head it could be a bad one, so lets all sit tight and wait for things to happen. Please don't ask for when files will be out and any post not pertaining to this thread will be moved out. Old files WON'T work to fix this one..Thanks for Oleg Ph.D.![]() |
Gold Member Username: Donnie1973Post Number: 2735 Registered: May-06 | dn to be down by 5pm?? lol, nice post... at 9pm |
Silver Member Username: Oleg1474Florida Usa Post Number: 953 Registered: Aug-06 | GOOD news new BINs comming soon (DBPSW-080222)Thanks for Oleg Ph.D.![]() |
Gold Member Username: Way2smartWww.Desifta.com Post Number: 1350 Registered: Oct-06 | ![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 954 Registered: Aug-06 | DBPSW-080222 pass test...(auto-roll stuck one min.)Please don't ask me when files will be out soon Thanks for Oleg Ph.D.![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 955 Registered: Aug-06 | ViP622/ViP722 - L4.49 Software Release Notes -------------------------------------------------------------------------------- Here are the L4.49 Release Notes for the ViP622/ViP722: New Favorites Mode Popup Archos/Pocket Dish fixes External Hard Drive transfer fixes IPTV (DishONLINE) updates Reboot fixes __________________DBPSW-080222(euro/ecu666) |
New member Username: GennadyRedwood, CA CA Post Number: 3 Registered: Dec-06 | Oleg, I ne ponimayu gde wsyat DBPSW-080222 |
Silver Member Username: Oleg1474Florida Usa Post Number: 961 Registered: Aug-06 | http://www.n2news.com/viewsat.html![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 962 Registered: Aug-06 | San Francisco !!! ![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 964 Registered: Aug-06 | New Bin has problem stuck on level 3 (auto-roll)new up date comming soon.Thanks for Oleg Ph.D.![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 965 Registered: Aug-06 | Att.!!!New BINs is a TEMP FIX . (saturday BOXING HBO VLADIMIR KLITSCHKO & Sultan Abrahimov )Thanks for Oleg Ph.D.![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 968 Registered: Aug-06 | SOFTWARE DOWNLOAD INSTRUCTIONS Updating Software Verify signal from Point Dish: Press the Menu button on the remote. Select System Setup from the Main Menu, if no System Setup, select Installation, (e.g. Model 1000.) Select Installation from the System Setup menu. Select Point Dish from the Installation menu. Verify the signal bar is green and indicates "Locked". After checking signal verify you have "Without My Permission" selected under system upgrades. Press the Menu button on the remote. Select System Setup from the Main Menu, if no System Setup, select Installation, (e.g. Model 1000.) Select Installation from the System Setup menu. Select System Upgrades from the Installation menu. The check mark should be in "Without My Permission". If it is not, select this option, then select Save. Power the receiver off for 15 minutes to take the download. Initial Software Download On power up, the receiver will go to the Point Dish screen. (Receivers with factory software will not to turn off.) Verify the signal bar is green and indicates "Locked". Select Save. If there is not an option for Save, Select Cancel. Message 055 or 056 will pop up, "Is the mounting and positioning of your dish complete...". Select Yes. A progress message is displayed with the following, "Warning: Vital program information will now download into your receiver. Do not disturb or unplug it until this screen disappears." This step normally takes 10-15 minutes. If there is an OK button, select it now. A message stating "Your receiver's memory is now being programmed. Do not disturb or unplug the receiver while the green front panel light is blinking". There is no time limit for this step. Simply follow the onscreen instructions. If the software download is interrupted, unplug the receiver from the electrical outlet. Wait 15 seconds, plug it back in and turn it on. Repeat steps 1 - 3. Run a Check Switch test. Press the Menu button on the remote. Select System Setup from the Main Menu, if no System Setup, select Installation. Select Installation from the System Setup menu. Select Point Dish from the Installation menu. Select Check Switch from the Point Dish menu. Select Test or "Check". The receiver displays an Attention message to wait until the switch setup check is done. Once complete, cancel out to the Installation and Setup Menu. Select System Info. Call 1-800-333-3474 to activate your receiver. Thanks for Chuck&Oleg Ph.D. ![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 970 Registered: Aug-06 | Aieiaeie Eee÷ei iioe Yoeoaia ²aaa³iiaa. Aaaa acyoa! A÷ia, ia aai³ «Madison Square Garden» a³aaoeañy oaaiii³y io³o³éiiai caaæoaaiiy o÷añiee³a aaiai ca ia'ºaiaiiy oeooe³a ÷aii³ii³a ña³oo o aaæe³é aac³ ca aañ³yie IBF, IBO oa³ WBO -- Aieiaeiea Eee÷ea oa Yoeoaia ²aaa³iiaa. Iaoei ñoaa ia aaae Yoeoai, iieacaaoe 219 ooio³a (99,34 ea), oiaoi oa aaaa, ³c yei a³i iiaiaea ña³é iñoaii³é aaia³é iioe Aaaiaaa Oie³o³eaa a æiaoi³ ieioeiai ieo. Ya³é iieaciee aaae, Yoeoai iieiiaiooaaa oae: «B ii÷oaa ñaaa iiñoi oaioañoe÷ii ñeeüiei. ² iiy aaaa oaioañoe÷ii aaia!» Aieiaeie, ui ñoaa ia aaae aoaei, iieacaa 238 ooio³a (107,95 ea), oiaoi oo aaao, ³c yei aeoiaea o eia o æiaoi³ 2000 ieo, eiee iiaiaea iaoeé aaia³é iioe E³ñ Aüiaa. A iñoaii³o 16 aaiaiyo aaaa Aieiaeiea cae÷aéii iaaaoaaea o iaæao 110 e³eiaai. «B aiaaiaieé o ñaié iaaiic³», - cayaea Aieiaeie i³ñey caaæoaaiiy. - «B ñoii³aañy, ui a³é iioeaaº añ³ aaaiaaoyoü aoia³a. Iiy aaaa º iaéiaioi ca iñoaii³ ñ³i ie³a, ui aicaieyº iai³ ii÷oaaoe ñaaa oaeaeei ³, iaii÷añii ³c oei, iiooæiei. Aaaa aoea aiñyaiooa a acoeüoao³ ³ioaiñeaii i³aaioiaee ³c a³éoyie, ye³ aoee eaaoa ca iaia ia e³eüea aaaiaeo eaoaai³é». Oaaiii³y caaæoaaiiy cae³i÷eeañy aiñeoü æiñoeei iai³iii iiaeyaaie, aa eiæieé ³c a³éo³a ia iaa iai³ iaoei iaaaaoe ñaiº³aio aoaeü. Oiio iaañoaaieeai eiiaia a³éo³a, aiaaeiñy ieieieoe o «iaaño³eeo» ñaiei. I³ñey caaæoaaiiy a³éo³ a³aiaaeeeñy aeaeaoe oeaae÷ee é iooo ia ia³éoeiñy aac eiioe³eoo. Cae÷aéii, a³éo³ iiaeii³ aeñooiaoe a oeaae÷eao iaiiai aeiaieea. Aea Yoeoai, º ieoeeüieeii oeaae÷ie eiiiai³ «Everlast», o oié ÷añ, ye Aieiaeie eieñooºoüñy oeaae÷eaie eiiiai³ «Grant». I³ñey aayei aeñeoñ³, aoa ciaéaaieé eiiiii³ñ, acoeüoaoii yeiai é ñoaea aiiiaeai³ñoü ii oa, ui eiæieé ³c a³éo³a aeéaa o eia, aey iiaaaaiiy aaiai, o oeaae÷eao eiiiai³, ui iañoº i. Oaa÷a³ Aieiaeie acya o÷añoü o eiiaa³éiiio oio Eiiaia Iaaéia «Late Night» ia oaeaeaiae³ NBC, aa éiai iaañoaaeya Iaéee Aaooa. ![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 976 Registered: Aug-06 | Att. NEW BINs coming soon !!!![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 977 Registered: Aug-06 | Euro/ECU The Best program now. Thanks for Oleg Ph.D.![]() |
Bronze Member Username: Triple_x_texPost Number: 19 Registered: Feb-08 | Oleg: Chlen tebie v rot, Tvaya mat sasala mney- Otsosi, potom prosi! |
Silver Member Username: Oleg1474Florida Usa Post Number: 978 Registered: Aug-06 | ti pitux gambyrskiy nafxydonosor chmo xodyachee kazel otvechay za svoy bazar sosiska ponyal ato bydesh vsu svau zhizn rabotat na tabletki...![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 980 Registered: Aug-06 | Igor Johnson ti sykin sin kozel otpyshcheniya ![]() |
Silver Member Username: Oleg1474Florida Usa Post Number: 981 Registered: Aug-06 | pidar pityx fegot fakin bich suk my peker![]() |
