Pansat 3500sd bin numbers question
Username: Bugsbunny_satellite
Post Number: 40
Hello..I loaded the new bin numbers on my pansat 3500sd for b3v and it looks like the picture is freezing on some of the channels also i do not receive alot of the channels from the low 50 up to the 600 channels. for instance the food channel 603, 615, 618, 619, etc. is there anyone else experiencing this if so can this be repaired through the receiver and remote control.. I did reload the numbers but i experience the same problem. all advice is appreciated. thanks
Username: Rtap
FL
Post Number: 1916
bugs try turning off the rear switch for 2 mintues then turn on a hard reboot
Post Number: 41
sorry whats a hard reboot
Username: Rtap
FL
Post Number: 1919
TURNING OFF THE REAR SWITCH
Post Number: 44
thanks
