What amp for 2 12 type r's
Username: Dupe112309
Post Number: 42
2 alpine type r.....500rms each...4 ohms dvc...lookin for a bass remote too. would i need to get something for 500rms to each, or would 300-400 be sufficient?
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 484
i got a mbquart RAA 1000 with a bass remote, i never used the bass remote so that fairly brand new, 200 shipped it could be yours, 1000 x 1 at one ohm, be perfect for them especially for stock electrical system
Post Number: 43
the type r's come either 4 ohm or 2 ohm i haven't bought them yet...how would i need to wire them?
Sandusky, Oh
Post Number: 485
i'd reccommed the dual 4, that way they will wire down to one ohm, and even in ur not interested in my amp or whatnot, its a lot easier findin a amp with 1000 watts at one ohm rather than two, and cheaper
Post Number: 44
would an amp that was rated somewhere between 300-400 rms for each channel be sufficient for the 2 500w rms subs? or should i really try to find a good amp that will put out that 500x2?
Username: Indoeli211
Post Number: 13
i have 2 type r 12s i have a 1000x1 only a 1 channel amp it pounds rockford fastogate is the shix.. 1000wats rms shouold do ... i also have a 500 rf amp on 7 6by9s eheheh
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1586
Get the AQ1200D. 1200X1 at 1 ohm. http://www.audioque.com/aq/AQamps.htm
Plus it's only $249 right now.
I have a Type R, and it can easily handle over 500w.
Username: N2audio
Lawrence, Ks USA
Post Number: 1488
300/400 each would be plenty. 500 ea would give you slightly more output, but barely enough to notice.
Username: Nd4spd18
Northwest PA
Post Number: 6437
x2 AQ 1200d amp would be great for those subs
Username: Hittin_so_hard
Villa rica, Georgia Usa
Post Number: 9
i got 2 alpine type r 12's and an audioque 1200d amp and it sounds great and was only 249.......it can easily pull more than 500rms per sub
Post Number: 47
so im lookin at kicker amps right now...could go with zx1000.1 and run it at 2 ohms for 500x2rms for $287.....but would i need any more power or would 500 be good enough and say 600w not really make too big a difference?
Username: Nd4spd18
Northwest PA
Post Number: 6447
You cannot use that amp. You need a 1 ohm stable amp for those subs, like the AQ.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1593
The AQ is cheaper, has more power and is just as good as, if not better than the Kicker amp.
Username: Nd4spd18
Northwest PA
Post Number: 6457
I wouldn't go that far...... I'd still say the kicker is the better amp. It won't work for his subs though.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1600
I stand corrected.
Username: Nd4spd18
Northwest PA
Post Number: 6470
Oh I didn't mean it like that..... you're entitled to your opinion but mine is that they are both good amps but the Kicker's a little better.
Like I said though, for those subs he needs a 1 ohm stable amp.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1604
I took no offense, I am still learning.
Post Number: 49
what's the reason i need a 1 ohm stable amp? the r's come in 2 and 4 ohm if that gives me any certain amps to look at....anybody got any suggestions? i'll look for that aq. is any special wiring needed for 1 ohm or any add-ons i'll need (like for the battery)? i had stock system before and now adding 2 amps.
Username: Nd4spd18
Northwest PA
Post Number: 6471
In the first post you said Dual 4 ohm, so I thought thats what your subs were.
If you didn't buy them yet, you can get the Dual 2 ohm, then you could use the Kicker amp or any other 2 ohm stable amp. For a 1 ohm stable amp you would get the dual 4s.
Post Number: 51
so which setup would you reccomend?.....kicker zx1000.1 with 2 2ohm r's or the aq 1200d with 2 4ohm r's?
the aq is 250 while the kicker is 287...so not too big a difference.
thanks a lot for helpin a new kid out. if i have 2 amps runnin in my car one kicker 650.4 and say the 1000.1, would i need to do anything with the electrical of the car?
Username: Nd4spd18
Northwest PA
Post Number: 6478
I'd go with the Kicker amp....... your stock electrical system may be alright with that but theres no way to know for sure.
Post Number: 52
what could happen? lol anything serious? also heard the type r's sound better in a sealed enclosure. was thinking about going for a dual enclosure.....but im really lookin for soem good bump comin down the road. ported or sealed?
Username: Nd4spd18
Northwest PA
Post Number: 6482
Do ported, still sounds good and more output....... if you draw too much current from your electrical you will see the voltage drop below 12 volts if goes you'd just have to turn it down or get HO alternator.
Post Number: 53
alright thanks a lot M.S. you really know your stuff.
Post Number: 54
i think i'm going to go with 0/1 ga kicker amp kits for both amps just incase i upgrade or anything
Post Number: 55
would a capacitor be necessary? what rating should it be be if i need one?
Username: Nd4spd18
Northwest PA
Post Number: 6531
No capacitor they don't help
Kicker amp kits are very good
Post Number: 56
thinkin about goin through crutchfield for a ported box....could get a dual with 1.25 cu.ft/sub or a dual with 1.75/sub...would bigger be better? got 2000 mustang cpe so i gotta measure and everything. both boxes would work as for the sub needs between .75 and 2.0 cu.ft
Username: Nd4spd18
Northwest PA
Post Number: 6539
Definetly no prefab boxes, they suck bad except the sealed ones, those are just ok.
www.fishercustoms.com
www.woodlawncabinetry.com
You can get a good box there. The box makes more difference than the subs in it............
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5205
search the subwoofer section, there are some guys selling customized boxes
