Username: Mj23dynasty They Love 2 Hate Me,
Most Hated a...
Post Number: 1618 Registered: Oct-07
Wednesday, February 27, 2008 - 12:49 GMT }Ok I'm trying to wire two 4 ohm DVC subs to a 1 ohn load. Now I kno how to do tht but I only know how to do tht to 1 terminal cup. Can any1 make me a diagram of how 2 wire 2 dvc 4 subs to a l ohm to 2 terminal cups. I kno I'm dumb blah blah lol
Username: Stateprop486 PA
Post Number: 755 Registered: Jan-08
Wednesday, February 27, 2008 - 13:00 GMT jus use 1 terminal cup then
1000 posts!!
Post Number: 14280 Registered: Jun-06
Wednesday, February 27, 2008 - 13:01 GMT Wait a minute. Are you trying to wire your subs to two seperate channels? (Two terminal cups)????
Most Hated a...
Post Number: 1619 Registered: Oct-07
Wednesday, February 27, 2008 - 13:07 GMT }Well woodlawn put 2 terminal cups on my box for some reason but every dual sub setup I've owned the box always had two terminal cups?}
1000 posts!!
Post Number: 14281 Registered: Jun-06
Wednesday, February 27, 2008 - 13:11 GMT One terminal cup will not be used.
Post Number: 756 Registered: Jan-08
Wednesday, February 27, 2008 - 13:19 GMT yea usually they put 2 terminal cups because sum ppl use 2 channel amps to run each woofer on a seperate channel. but u have the SAZ-1500D and thats a Mono Class-D amp so you would only have to use 1 terminal cup and just forget the other one exist.
Most Hated a...
Post Number: 1620 Registered: Oct-07
Wednesday, February 27, 2008 - 13:22 GMT }Ok I thought something was wrong lol ok thanx paul.
Username: Kravenblood Ohio
Hmmm
Post Number: 376 Registered: Aug-05
Wednesday, February 27, 2008 - 14:39 GMT lol or you can wire each sub to a 2 ohm load to each terminal cup then parrelel (sp) the 2 cups
Username: Rovin 4 10 Pioneer...
Post Number: 13241 Registered: Jul-05
Wednesday, February 27, 2008 - 14:55 GMT ^^^thats what i would do .....
Username: Nd4spd18 Northwest PA
Post Number: 6513 Registered: Jul-06
Wednesday, February 27, 2008 - 19:38 GMT ^^^^^ x3
Username: Kingandsons07 Lincoln,
Nebraska
U.S.A
Post Number: 768 Registered: Feb-07
Wednesday, February 27, 2008 - 19:40 GMT ^^^^^^x4
Username: Th3pwn3r Post Number:...
Post Number: 7040 Registered: Jul-06
Wednesday, February 27, 2008 - 19:40 GMT Wow, Dwight don't you learn anything that goes on here? What a bad question.
