Bronze Member Username: DuckaShelby Township, MI United States Post Number: 57 Registered: Jan-08 | I want something to reduce the bass that goes to the normal speakers in my car but does not reduce the output/limit the range of my subwoofers. I think that means that I want to buy an Equalizer. Can anyone confirm that? Also is this a decent equalizer for what I want to get done? Keep in mind I dont want to limit my subs at all. If there is a better eq in that price range for what I want let me know. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17604 Can anyone tell me how to install an eq or send me a website that will tell me? Thanks a lot, Kevin |
Platinum Member Username: BestmankindLos Angeles, CA Post Number: 18917 Registered: Oct-05 | couldn't you turn the bass down on the eq on your headunit? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 763 Registered: Feb-07 | i would say get a new h.u cdt-9887 ftw |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 58 Registered: Jan-08 | Im not really sure if i can turn the bass down to just the speakers without turning down the subs. I have the JVC KD-AR880 h.u. http://mobile.jvc.com/Aproduct.jsp?modelId=MODL027896&pathId=142&page=1 |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 105 Registered: Feb-08 | yeah everyhead unit i have owned you can not just turn the bass down in just the high speakers but buy a h.u. with a seperate sub out put turn down the eq lows all the way then turn the sub level volume all the way up thats how i did it then adjust amp accordingly |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 106 Registered: Feb-08 | a leave the loudness OFF too |
Gold Member Username: InsearchofbassPost Number: 8175 Registered: Jun-04 | if your headunit has subwoofer controls you use that to balance the subwoofer output ...the regular bass settings on the headunit are what boosts the bass frequencies to your highs so keep that setting down...if that doesnt work you could buy bass blockers for your highs to make it a simple fix |
Gold Member Username: InsearchofbassPost Number: 8176 Registered: Jun-04 | oh and like zack kraus said leave the bass boost off |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 13245 Registered: Jul-05 | better u buy a good 3way crossover instead of a eq or preamp.... |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin MY SUBS GET ... Post Number: 1536 Registered: Mar-07 | doesnt you HU have a high pass filter? |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 60 Registered: Jan-08 | Im not really sure. Ive been away from it for too long(away at scool without my car). But even if it does wont that still reduce the amount of bass going to the subs? |
Gold Member Username: camBC Canada Post Number: 2055 Registered: Nov-06 | It should just high-pass the stereo pre-outs. |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 61 Registered: Jan-08 | alright cool. So just take off bass boost/loudness and turn on the hpf? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6517 Registered: Jul-06 | No HPF on the HU...... I know b/c I have one. Of couse I never drive any speakres with a HU so it doesn't matter. Bass blockers would be what you need. They're cheap. |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 64 Registered: Jan-08 | alright thanks alot M.S. anyone got any tips for taking off the pannel for the door of an alero to get to the speakers? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6527 Registered: Jul-06 | If those are stock speakers you may consider putting in good ones......... the difference will shock you. |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 65 Registered: Jan-08 | really? The stock speakers in an alero are pretty good and the fact that they have tweeters that are up by side mirrors is also really nice. They sound great except they get a bit distorted once the music is way up unless i reduce the bass a bit. I would like to leave the tweeters running and Im not really comfortable with taking apart my car. I could get some new 6x9s in the back but im pretty satisfied with the speakers in general. I think they would be even better and go even louder if i reduced the distorion by removing the low bass to them. I used to have a civic that I put all new speakers in, but the stock ones were complete garbage. But just for giggles... What kind of speakers would you consider to be good ones? I got a alero (4x6's and 6x9's) |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6532 Registered: Jul-06 | Well if you're satisfied with them thats all that matters....... I just haven't heard many stock systems that sounded good. The ones that Lexus has is really the only one........... the monsoon in audi/VW and Bose in GM are ok, nothing great. |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 67 Registered: Jan-08 | It doesnt get the best bass... Thats why I got subs. |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 107 Registered: Feb-08 | dude you will crap yourself if you get new highs and an amp to push them |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 108 Registered: Feb-08 | i put two new 6.5 2 new 4 by 6 and flush mounted two tweeters in the top of my box and i can hardly stand it lol |
Bronze Member Username: DuckaShelby Township, MI United States Post Number: 69 Registered: Jan-08 | I might over summer when I have more cash/time. For now im just gunna worry about pickin up some new subs wire and an amp. |
