Range Rover subwoofer.....please help!!
Username: Boulderlouis
Hello,
im thinking about adding some bass to my new range rover. i dont want the bass to be overwhelming or extremely loud. i just want to seamlessly add stronger but clean bass to the stock system. I also don't want the subs to take up all my trunk space! a friends suggested putting in 2 10" w3s. Since i don't know all that much about car audio i need your help! any suggestions? thanks in advance....
Username: Nickyp0219
Post Number: 730
put a 10w7 and a 500/1, i mean if you can afford a new range, you can afford jl
jl is great stuff, just pricy
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1596
I'd take a W6 in a high output box with a 500/1. Beatiful SQ woofer.
Username: Stateprop486
PA
Post Number: 724
"i mean if you can afford a new range rover, you can afford jl"
^x2 lol for the most part true. not many ppl can afford an range rover obviously u have $$$$. haha
Post Number: 731
^^ that could work as well
just shootin ideas out
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 354
you want one sub or the deuce?
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2428
Hertz Audio Mille 2500
JL Audio W6 10
Image Dynamics IDmax 10
Boston Acoustics G5 10
All would work well with a JL Audio 500/1.
im definitely going to do JL. what is the difference between a w3, a w6, and and w7? again, crazy loud bass is not that important to me. just something that will sound crisp and that wont use all my trunk space. and lastly what can i expect to spend on something like this? thanks to everyone who has posted.....
Clarion Hert...
Post Number: 2429
If your going to use JL Audio go with a W6. They are by far there best sounding subs.
W6 10s online are around $275, ebay prices can vary, and at a shop you will probably spend closer to $400-450 per sub.
Personally the exact setup I would run is 2 W6 10"s in a small sealed box and a JL 1000/1 amp. It would sound very clean/accurate, and you should be extremely happy with how it sounds.
thanks jake
Clarion Hert...
Post Number: 2431
Anytime man.
What colors your Rover? Post some pics up when you get everything installed!
will do, its white with black interior
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4405
pics now!!! haha i agree the W6s would sound great. I would personally go with the mille's though because they look sick and no one has them.
