Some weird things are happening latelly to my connection well..I have 2 dishes on my roof one is a twin dish pro that i use for my echo 7 and echo 9,10 and the other is for my international channels that i use for echo 3. the antenas are both connected to the dp-34 multiswitch. one cable goes to the livingroom and the other goes to my room. in my livingroom i have a viewsat platinun and on my room i have a pansat 3500sd since i was loosing signal in my antenas in the past , i was forced to buy the dishpro adapter in order to power it up the antenas. untill here everything is fine.. now comes the problem.
In the livingroom i have perfect signal, the cable is copnected traight to the box and i can scan all the channels on all the echostar pachage, i rarelly miss signal.
In my room(pansat3500sd) the box is conneced to the dispro adapter that power up the antena,and i constantly loose signal, and when i do a Blindscan on echo 8 i get some international channels that bellongs to echo 3 and the most mazing thing is that when i turn to those channels They do work.. .. i also get chanels in echo 3 that bellongs to echo 7.. its a mess. and most of the time i have the NO SIGNAL or SCRAMBLED message.what am i doing wrong?
ps:i have the dp adapter conected next to my pansat3500sd to power up the antena, when i switch the viewsat to my room i am still loozing signal, so i dont think its a box issue.... what am ai doing wrong
