Satopia full EMU update
Username: Nydas
Post Number: 8396
There are some ill-informed people who do not wish to acknowledge that BlackList exists and is alive and have working team.
Blacklist undertook to do a full EMU for Satopia '" He has now posted version
Ver_05A-Full-Beta.
All I can say now is that you should watch for full EMU for Pansats.
[link removed]
C/P
ST200208-XXBL_Ver_05A-Full-Beta
Satopia Users,
This is Satopia_BL_V05_Beta File, Both DN + BV Fix in new EMU.
Both ones are tested and working properly. Globecast will probably work too, but need to be tested. We're now back on right track for top FTA manufactuer with our new EMU. More and more upgrades will make users happier than ever. Be happy all !
Blacklist
ST200208-XXBL_Ver_05A-Full-Beta.zip (1.26 MB)
Username: Ong_tu
Post Number: 253
More C/P is that all you do here?
Username: Nydas
Post Number: 8399
Ong_tu : Shut up.
You don;t even know what Satopia or Pansat is.
Username: Krishn
Post Number: 82
One should be cautiously optimistic, even assuming that it is in fact full emu, especially with lower end Pansat models like 2700 which has only a 81 MHz processor, 2 Mb Flash Memory and 8 Mb SDRAM
Username: Nydas
Post Number: 8411
People said about Pansat 2500, you can't do this and you can't do that.
When I see posts of VS ultra changing channels with freezing and autorolling after 10 minutes, I can say that Pansat 2500 converted - did not do that.
Where there is a will there is away.
Username: Nydas
Post Number: 8414
bump
Username: Newbiehater
FTAwhew what a stink
Post Number: 167
Being tottally optimistic about full emu at this point in the game with a new card change in the works is redundant.
Username: Cybermaster
Post Number: 126
Does this mean we can input codes manually during the black outs and watch tv.
Post Number: 170
Full emu means never down,no need to manully input anything or ever upgrade bins again. But if you believe this , your
Username: Ez2ctv
Platinum Mem...
Post Number: 54
"Does this mean we can input codes manually during the black outs and watch tv."
No it means we should not have to do anything a full EMU will be just like trus plastic. What the providers send down to plastic should also be sent to a FTA box with full EMU.
Ain't going to happen, full EMU of plastic is BS
Post Number: 171
Another co-incidence is teamBL claims to working on this wile a card swap is in process , thus his azz is saved by this so called timming and event. lmao more bl bullshitt.
Post Number: 172
Last card swap he promised his "superbin" . lmao , same old same old nothing new here.
Username: Nydas
Post Number: 8489
Neither hate for BL nor hate of Pansat is going to make the full EMU go away.
Accept the obvious. It is there in beta version 5, in keeping with the industry accepted time frame.
Username: Lklives
Post Number: 13992
If BL had full emu, Satopia wouldn't have gone down as McLink stated..
Captiveworks, which never blinked, has almost a full emu...with CNX a close 2nd..
Username: Rtap
FL
Post Number: 1895
i think BL is seeing the light at the end of the tunnel lol
Username: Nydas
Post Number: 8493
Some people show their ignorance so obviously. They do not have any idea of nor have understood software development.
All companies including IBM, Microsoft,Firefox etc. have a cycle of development with various versions and Beta releases. The history of development of the EMU on Satopia is totally encouraging and ahead of the cycles seen in most software development projects.
As I said elsewhere, there is no room now in the FTA world for ignorant egoistic ex-mods. You can hunt as much as you like, but till you become humble and LEARN you are permanently redunant.
Post Number: 183
Nalin , If you had the slightest clue of how emulation works you would realize how ignorant and stubborn and EGOTISTIC YOU REALLY ARE.
Second you would realize it can't be done without having it take updates in the stream ,and at this time, that and some parts of the rom still are unknown.
Go back to paki land you pos.
Username: Dssbss
Post Number: 10
not a card swap coming,its a wife swap,now thats full EMU
Username: Nydas
Post Number: 8561
For the latest Vista update, go to
www.microsoft.com
Username: Nydas
Post Number: 8562
ST250208-XXBL_Ver_06A-Full-Beta
[link removed]
