Need help with an amp of 1000+ watts
Username: Rayne225
Peoria, AZ US of A
Post Number: 9
im lookin in to get an amp with 1000+ watts, maybe more into the 1500 range
i need some opinions on infinity, jbl, kicker, mb quart, and rockford fosgate amps
so far, the kicker and fosgate are at my max price range if i choose to get those
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5208
what are you trying to push? and voice coil config.
It's not a rule or something but you might find 2 ohm Stable monoblocks more expensive that 1 ohm stable.
Username: Stateprop486
PA
Post Number: 845
AQ 1200D @ 1ohm will produce more then rated. $249 shipped cant beat that price for true rms.
http://www.audioque.com/aq/AQamps.htm
Username: Rayne225
Peoria, AZ US of A
Post Number: 10
i might get a Memphis MOJO12D2 or a Fi BL12
voice config im not sure about due to inexperience with subs, but my friend's has a dual voice coil, and im guessing thats better
ive also heard that running on lower ohms is better, not sure if this is true or not
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13968
Buy my D61500.1 does 1800rms @1ohm :-)
Username: Rayne225
Peoria, AZ US of A
Post Number: 11
kind of on a budget, highest is probably around the price of an ED NINe.1
im open to amps that can compare themselves with the kicker az1500.1 or the aq1200D (both do sound tempting, just gotta coin toss them if still comes down to those 2)
Username: 420alldaylong
Post Number: 3311
Fi BL 12" Dual 2ohm
AQ1200D
And wire it to 1ohm like in the link below.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Post Number: 3312
Chauncey Brown
How much are you asking for the Diamond D6 1500.1?
Post Number: 13975
$305shipped and insured and you will get it the day after you pay :-)
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1883
good deal on the mmats amp.
Username: •cam•
BC Canada
Post Number: 2123
The Mmats? Huh?
"ive also heard that running on lower ohms is better, not sure if this is true or not"
I suppose it depends. If you're a competitor, then you may want to put less impedance on your amp to get more power. With regards to amplitude, someone said that they wired their subs down to a lower impedance and it was just as loud as before due to the decrease in torque from the paralleled coils. Higher impedances are much easier on your amp as well. The damping factor increases too.
Username: N2audio
Lawrence, Ks USA
Post Number: 1492
"decrease in torque from the paralleled coils."
WTF?
