New member Username: Boxer1Post Number: 2 Registered: Feb-08 | okay i have a pioneer premier 320 amp my sub space is .7 cubic ft. i need some advice on 10" subs that would be the best fit for my set up. My head unit is a sony cdx-gt710. please help |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13953 Registered: Jul-05 | budget, and specs on that amp.. |
New member Username: Boxer1Post Number: 3 Registered: Feb-08 | the amp has 2 30 amp fuses and says: 50wx2 2/4ohm 20-20,000Hz THD=0.08% 200wx1 1/4 ohm 20-20,000Hz THD=0.8% 1-8 ohm I was told the amp put out more power than it states? cheap 10" subs but i want it to sound good. what do you think? |
New member Username: Boxer1Post Number: 4 Registered: Feb-08 | the amp is a pioneer prs-x320 if that helps |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13954 Registered: Jul-05 | how much is cheap.. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 779 Registered: Feb-07 | u may need a better amp then that heres what i found http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2845 and wire it the way in the 2nd pic http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=3 that will put u at a 2ohm load. i say get a biger amp thats putting out 400rms @ 2ohms |
New member Username: Boxer1Post Number: 5 Registered: Feb-08 | What kind of amp do you recommend? belive it or not i spent over 300 dollars on this amp around 1999. I kinda figured that i should get a better amp. the box i have is a sealed box 7" mounting depth and its .7 cubic ft. how much is cheap.. under $200 amp somewhere around 200 give or take. Any suggestions?? |
Gold Member Username: camBC Canada Post Number: 2077 Registered: Nov-06 | I think that amp will do you fine. An eD SQ10 is probably what you are looking for. |
