Diamond Audio
C
My local shope starting carrying Diamond Audio subs. The owner swears by them. Has anyone heard these? Are they good for sound quality. I was going to get a Kappa Perfect 12.1, but now he's got me interested in these Diamonds. What do yall think is the best pick for sound quality and a little bit of SPL???
Username: Glasswolf
Post Number: 44
Diamond Audio is a terrific company.
the subs are good. their Hex components rock, too.
give them a listen some time.
Username: Chippa
They have three classes of subs. Which are going to be awesome for SQ/SPL for under $200?
Username: Glasswolf
Post Number: 49
I haven't looked at their current pricing so I couldn't tell ya there. Best to ask the guy who runs that shop, and tell him the kind of car you have, and type of music you prefer.
that'll make a difference, as will the amount of power you can feed them.
Username: Chippa
Post Number: 11
Are these subs in the running for a top SQ competitor????
Username: Glasswolf
Post Number: 157
They're good.
There are better subs, but those are quite good.
really depends on what you're willing to spend.
Username: Chippa
Post Number: 18
I'm willing to spend about $250. Is that not enough to get a good high sound quality sub? I can get a 12" Diamond Audio M6 for $289. That is the absolute most I can spend on one 12. Should I look elsewhere or is this a great bargain?
Username: Glasswolf
Post Number: 220
Look at the Onyx SST12.4
12" 240wRMS 4 Ohms SVC for $210 each
www.onyxmobileaudio.com
or the Adire Shiva 12" sub for about $120 each at 650wRMS
www.adireaudio.com
