im looking for a subwoofer to replace the stock sub on the back baffle board so i just wanted to know some of your opions on a good 10" free air sub?? thanks.
With Lexus sound systems, they specifically design all the speakers in there for the vehicle. I highly doubt you'd get any better performance simply by putting a different speaker in there, in fact I'd bet on worse.
Now if you added a real sub, with a box and amp, then yeah.
In an expensive car like that they're not gonna put some pos speaker in it. Why did it pop? If you don't correct the problem you're bound to repeat your dilemma.
