Silver Member Username: Thakkar2000
Post Number: 192 Registered: Jun-06
Posted on menu-----installation----advanced settings-----then u will get a screen which will have TP: 12443 VIDEO- auto AUDIO- auto PCR- auto makesure TP is 12443 and change the (Type it in) VIDEO:5666 AUDIO:5667 PCR: 5666 press OK...it will recan..and then for me the channel was listed as CH-A |
Bronze Member Username: Bluegillbill
Post Number: 34 Registered: Sep-06
Posted on what is star plus is it worth scanning anyone |
Silver Member Username: Adave
Post Number: 131 Registered: Jun-06
Posted on prime hindi channel in india |
Silver Member Username: Vsp
Post Number: 236 Registered: Jun-06
Posted on finally star plus is on after a long wait |
Silver Member Username: Rekman
Mntl-Quebec-...
Post Number: 308 Registered: Jun-06
Posted on V??? can u explain how you het the STAR PLUS indian channel.. Did you Really get it?? Explain |
Silver Member Username: Plymouth
Quebec city,
Quebec
Post Number: 243 Registered: Jan-08
Posted on MKM parle tu francais |
Quebec city,
Quebec
Post Number: 244 Registered: Jan-08
Posted on Read all posts and see your self |
Post Number: 240 Registered: Jun-06
Posted on MKM ON PANSAT 2700, PANSAT 2700 CLONES AND PANSAT 2500/flu CONVERTED. Menu/Installation/Advanced scan Select Echo 3 (61.5 ) Down frequency = 12443 MHZ Symbol rate= 20.000 Msps Polarity = Horizontal Channel name = N/A (Leave it blank) Video PID = 5666 Audio PID = 5667 PCR PID = 5666 |
Bronze Member Username: Old_bin
Post Number: 15 Registered: Oct-07
Posted on Any tamil tv channel is up? |
