Silver Member Username: Mdl97Post Number: 129 Registered: Jan-06 | still autorolling even after i loaded factory bin and then new bin.i even rebooted several times....please help as this is very frustrating.....thanks |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 193 Registered: Jan-08 | on what sat Ramiro |
Silver Member Username: Mdl97Post Number: 130 Registered: Jan-06 | on both i assume...i have no channels at all. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 195 Registered: Jan-08 | On dn see my post: https://www.ecoustics.com/electronics/forum/home-video/452524.html |
Silver Member Username: Mdl97Post Number: 132 Registered: Jan-06 | dude im lost...im totally new at this.how do i create a new sat and do everything else? |
Silver Member Username: Mdl97Post Number: 133 Registered: Jan-06 | hello plymouth? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 196 Registered: Jan-08 | Ramiro is it on dish |
Silver Member Username: Mdl97Post Number: 134 Registered: Jan-06 | yes its on dish |
Silver Member Username: MetallicaPost Number: 168 Registered: Jan-08 | Ramiro are you watching 110 and 119??? and post your SAT setting so i can check it is the right setting. |
Silver Member Username: Mdl97Post Number: 135 Registered: Jan-06 | yes its both 119 and 110.how do i check the sat setting? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 198 Registered: Jan-08 | Metallica that not a problem of setup i thing most have the same problem on viewsat "lost info setup or autoroll only on Dish |
Silver Member Username: Mdl97Post Number: 136 Registered: Jan-06 | huh?how do i check sat setting |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 199 Registered: Jan-08 | Is it viewsat ultra |
Silver Member Username: Mdl97Post Number: 138 Registered: Jan-06 | no its a viewsat platinum |
Silver Member Username: MetallicaPost Number: 169 Registered: Jan-08 | go to menu installation antenna setup SATELLITE and choose EchoStar 7 119.W..and write down everything under there and do the same with EchoStar 8,10 110W again. |
Silver Member Username: Mdl97Post Number: 139 Registered: Jan-06 | lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 1 motor-off legacy sw-none for 8,10 lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 2 motor-off legacy sw-none |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 200 Registered: Jan-08 | I thing this is the same. With remote push menu,installaion,antenna setup and said satellite ...... lnb power ...... lnb type........ lnb high........ lnb low......... tp freq......... diseq 1.0....... motor........... legacy switch... give what you see |
Silver Member Username: MetallicaPost Number: 170 Registered: Jan-08 | Plymouth..my Extreme don't even need autoroll this morning..after i finish loading the bin turn it off connect the cable back in turn it back on there TV. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 201 Registered: Jan-08 | Just try it, if not work reply |
Silver Member Username: MetallicaPost Number: 171 Registered: Jan-08 | Ramiro your setting is right.. i think you better load the new bin 1 more time see if it work.. DBPSW-080222P DN & BEV Fixed |
Silver Member Username: Mdl97Post Number: 140 Registered: Jan-06 | i have already done that.i just think my box is fried somehow. |
Silver Member Username: MetallicaPost Number: 172 Registered: Jan-08 | no your box are still alive and breathing because you can go to the menu like that. ok this is the last clue i have..turn it off from the back than turn it back on than tune to channel 200 CNN and let it roll..i have read some post some peoples said that channel roll faster i guess..no more clue. |
Gold Member Username: Saqeeb9000Post Number: 2480 Registered: Oct-07 | ramiro do a factory reset and then reload the bin.. if that doesn't work load the factory bin and reload the new bin again... } |
Silver Member Username: Mdl97Post Number: 141 Registered: Jan-06 | i have also done that to.ive done it on several occassions.thanks for all your guys help...i truly appreciated it. |
Gold Member Username: Saqeeb9000Post Number: 2482 Registered: Oct-07 | change lnbtype to standard... this might me the problem. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 202 Registered: Jan-08 | if not come back and try whati said |
Silver Member Username: Mdl97Post Number: 142 Registered: Jan-06 | changed to standard still autorolling... |
Silver Member Username: ImnycusaPost Number: 129 Registered: Jun-06 | i have similar issue with ultra. loaded the new bin twice, did factory reset, turned the rear power switch on and off, but no video or audio message stll on. wonder what course of action should i take now. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 204 Registered: Jan-08 | Ok listen me now go to menu installation 0000 pin code channel scan go down with arrow on fold+ add sat ok yousee on top usersat-1 now rigth arrow on antenna ok on "motor" select usals with right arrow up arrow put 1190 and down arrow for west and ok end ok lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 1 motor-off legacy sw-none lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 2 motor-off legacy sw-none end ok now blind scan frequency step 12 polarization all scan start press ok "press ok" standby and save go try on remote touch sat choose echostar7 dont remember autoscan echostar7 GOOD LUCK Ramiro and imnyc |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 206 Registered: Jan-08 | Reply please if work thanks |
Silver Member Username: ImnycusaPost Number: 131 Registered: Jun-06 | i installed the factory bin and reinstalled latest bin in the Ultra, check all the sat settings found same as above,rescan the sats 119 and 148 but still "no video or audio" message. i cant understand the problem. |
New member Username: Teehee123Post Number: 7 Registered: Jan-08 | where did u download the file from? sometimes a corrupt file can be a problem...also try uploading it through the cables rather than a USB as sometimes that makes a difference as well...gooddluck |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 214 Registered: Jan-08 | Ok listen me now go to menu installation 0000 pin code channel scan go down with arrow on fold+ add sat ok yousee on top usersat-1 now rigth arrow on antenna ok on "motor" select usals with right arrow up arrow put 1190 and down arrow for west and ok end ok lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 1 motor-off legacy sw-none lnb power-on lnb type-ocs-dp lnb freq-11250 22khz-off tp freq-12224 diseqc1.0-port 2 motor-off legacy sw-none end ok now blind scan frequency step 12 polarization all scan start press ok "press ok" standby and save go try on remote touch sat choose echostar7 dont remember autoscan echostar7 GOOD LUCK Ramiro and imnyc |
Bronze Member Username: XdetoursxPost Number: 25 Registered: Dec-07 | Funny how everyone was saying how great VS is and how they are first again with the new bin. Maybe the VS coders should take their time and get it right the first time. |
Silver Member Username: Mdl97Post Number: 143 Registered: Jan-06 | thanks plymouth ill try later today and post the results.... |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 223 Registered: Jan-08 | Xdetoursx the problem is viewsat is No1 sales and like Microsoft are attacked by some not nice. I dont see why you comment this. Competitor or Charlibev Guy |
