hello, this maybe the wrong section, but i was unable to go into the receiver section
have a 5th gen prelude in storage since Nov. car has a brand new battery before it went in,
installed a new sony deck, didn't start the car for a month, when i tried the battery was comnpletely dead.
followed all instruciton on wiring harness and deck manual, overall easy install.
the only wires not being used from the deck are the 2 remote wires, 1 for amp, and 1 for power antenna.
the prelude does not come with a power antenna, (intergrated into rear window) but i have been told to hook up the remote antenna wire cause im getting constant power if i dont, that doesn't really make sense, but is this correct?
The three beeps are normal. I've had Sony HU's that have done this. Not sure why though. You don't have to worry about the two remote leads either. The Majority of HU's i've seen have them and they don't need to be connected to anything for the HU itself to turn off.
I doubt it that the HU could be draining so much power to kill a brand new battery. My best bet would be that its something else. I mean can you turn your headlights and things on?
just get the car jumped and then once a week turn the car on to charge the bat. did you ever do this with the old deck? or did you leave a door open? sometimes when a door is left open the car will drain its own bat with the door light being left on. if you have a security light that might make the bat die.
lots of things can make your car bat die. don't quikly come to the conclusion its the deck
The 3 beeps is a "just letting you know your HU is still connected and you should detach the face plate and hide it or people will steal it" warning beep.
Other than that the battery could have been bad to start with as I bought a battery and it was toast withing 4 months, it was practically dead when I bought it. Yay for 5 year warranty though.
nothing would turn on, no headlights not even interior lights would come on, the battery was a complete zero,
i did jump the car that time and let it run to charge the battery. a may let it charge next time, and then i will disconnect it, if its dead next time i hook it up, then i know its the battery, i think i have a 2 year warranty.
thx, i just needed to make sure i was right, the antenna remote wire didn't make any sense to connect since its the deck sending the signal when on, not the other way around.
A HU might take a tiny amount of current to run the memory but should take a while longer than a month to kill a good battery. Are you sure it was charged good? It takes a long time to charge a battery running a car, like hours. Cold will weaken a battery also, too weak and too cold it will freeze.
the batter is brand new, purchased in Nov, and put in storage. plus ran the car every few weeks after that so it should have been fine even with the cold in the garage.
i'll be hones with you in a situation like this its either a sh!t battery or something is wrong with the electrics in your car and is not turning off when it should be. in that case you need to take it to a garage or something so they can track the drain down for you.
You can only go maybe 2 months on a good battery in those temps. I'd recommend you take the battery out and put in your house, if not at least take a cable loose from it. Also you need to charge it like a whole day to get it topped off.
