Question About Getting BEV and DN On One Receiver
Username: Upreferee
Post Number: 39
If you have 2 dishes (1 for BEV and 1 for DN)feeding into 1 receiver, how are the channels separated? Are the 2 providers automatically separated when you do the scanning? You toggle between the 2 via the SAT button on the remote?
Do you just feed the 2 BEV LNBs into port 3 and 4 of the Disq.?
Username: Dimwitt
Post Number: 432
You toggle between the 2 via the SAT button on the remote---yes
Do you just feed the 2 BEV LNBs into port 3 and 4 of the Disq---yes
Username: Brucester
Post Number: 1288
you need a swithc to got both on one box put cable in to the switch it will have a place for lmb1&2&3&4 and one out if you put bev in to the switch lmb1 then on your box when you go to scan the sats put your lmb seatings on lmb1 then on the dish net sat put the cable in to lmb 3 then when you go to scan dish net put your lmb seating on lmb3 then scan then exit out to tv the switch will no when your on dish net and send the right sat ch and when on bev the switch will no hope this helps
