Problem?!?!?
Username: Davidt487
Texas
Post Number: 93
Im still trying to figure out what could be causing me to have to turn the gain on my amp 3/4 of the way up to get any power from it.
i cant figure out what could be causing this
Username: Bonhamd
Northern, Michigan USA
Post Number: 336
maybe bad connections or bad pre out voltage
get a dmm on the amp and check
Username: Surferdude9371
Im BTL Bumpin
Post Number: 682
all the connections good?
Im BTL Bumpin
Post Number: 683
make sure the rcas r fully plugged in the back of the hu
Username: Davidt487
Texas
Post Number: 94
ive been over everything several times it works but i have to turn the gain up to 3/4 to get any real power from my amp
hifonics 2006d
eclipse cd8445 (8 volts)
Im BTL Bumpin
Post Number: 684
sounds like a bad amp
Username: Shade
Moxee, Wa U.S.
Post Number: 567
sub volume on the deck is at?!
Username: Davidt487
Texas
Post Number: 95
Username: Shade
Moxee, Wa U.S.
Post Number: 568
what are your subs wired too?
Username: Davidt487
Texas
Post Number: 96
1 ohm
12" re sx dual 2
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5967
Check the cross-over settings on the amp and Hu.
Also, check the RCA's and make sure you are getting a good signal to the amp.
Username: Davidt487
Texas
Post Number: 100
ive been through the setting several times if thats it ill never find it.
i called eclipse they said there is no what to check the output voltage with out an o scope and i dont have on so.
Username: Nd4spd18
Northwest PA
Post Number: 6370
BS you use use a DMM to check voltage
Scope is needed to benchtesting output power though.
Username: Davidt487
Texas
Post Number: 102
that is what the guy at eclipse tech support told me.
also i thought i might have a ground problem so i ran 0 guage from the frame to the - battery terminal and from the firewall to the - terminal
now my voltage runs at like 15 is that good or bad?
Post Number: 5970
Do you have another amp you can hook up just to test? Try that if you can.
Also, to test output on the RCA's...Just use a DMM. Disconect the RCA's from the amp and put one lead on the center pin and another on the outer casing. Run a 60hz tone and see what voltage you get at the RCA.
Username: Davidt487
Texas
Post Number: 103
what should i set the dmm to ac or dc
Post Number: 5971
Ac
Username: Davidt487
Texas
Post Number: 104
first off i have a cheap dmm but i couldnt get a a tenth out so should i just pack up my cd player and send it in for repair
Username: Davidt487
Texas
Post Number: 105
what if i bought a low output conv. and hook it up would that tell me if its my output voltage?
Username: Spivey17323
Dunellen, New jersey 15 inch Alph...
Post Number: 1252
are your subs wired right?
Username: Davidt487
Texas
Post Number: 106
yea
