New member Username: Donjuan3316Post Number: 4 Registered: Feb-08 | I'm going to get 2 dual kicker cvr 10's 2 ohms. Alot of places offer that package deal with the subs loaded into a ported kicker box. I just need someone to give me input as to whether i should go with the loaded kicker box or just try and find my own vented box and put the subs in the box myself. |
Gold Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 1457 Registered: Oct-05 | It depends.... I'm guessing you havent bought the subs yet. Are you handy with tools? Think you can build a box yourself? (wood, glue, screws, clamps, saw) Usually those package deals are not worth the money. Especially @ places like BestBuy and Circuit City. How much did you plan to spend on that package deal? |
New member Username: Donjuan3316Post Number: 5 Registered: Feb-08 | i'm not comfortable with building my own box honestly. i'm ordering the loaded box online and its listed at like 189.99 loaded with the subs here's the link http://www.gooddeals18.com/product/DCVR102?meta=FRG the other packages i found for same exact thing were like 349.00. so if this is loaded box is good of course i'll get it cuz its alot cheaper. but if it isn't i already have a box lined up that i'm gonna buy. |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 5535 Registered: Apr-06 | you could build your own box for very cheap.... all supplies at home depot only costs in the vicinity of 40-50 i can design you a box...better then spending uneseccary money. |
