I have a vs extreme the last few files that i uploaded have not worked. all it does is autoroll the preview channels come in right away but all other channels are blacked out and just rolling. I did a factory reset and reloaded the factory bin then loaded the latest file still not working. others are using the same file with no problems. Any ideas would be great
you can try to turn off the auto roll, but it never work for me, it would showed no audio/video signal instead.
try to manually input the keys if they are current, or switch off from the back and wait couple of minutes before reboot, it help the new bin and auto roll to kick in.
Tried that still no good. The weird thing is that Bev rolls and plays fine just don't understand Could the switch possibly be faulty? Like I said though I have full strength and exellent quality. All I can say is good times.
the 0211 still work on my vs with dn, I did not try the 0214 for bv.
I have tried several times to set up the bv, I have pretty good signal/quality, scanned in around 250 channels, but just keep rolling, I dunno the problems either, still trying to figure out only when dn is down.
do into the menu and go into the autoroll and click autoroll for both bev and dish i think by mistake you must have clicked on the option of bev autoroll and dn is turned off just try it
I went in and tried the auto roll thing but no sucsess. I do get a couple of channels in the 200's mostly shopping but nothing eles in dn. Bev is fine no problems there.
Never load bin from totalfta we think it's Dn hijack site. you have a virus in your box, after 2 weeks, the only think who resolved my problem :you create a new satellite tell me what echostar you listen
