Silver Member Username: PoyitoPost Number: 585 Registered: Dec-07 | VIVIANA LO QUE PASA ES QUE ELLOS CAMBIAN EL TIMER Y AL PONERLO DE REGRESO MUCHOS BINES VIEJOS TRABAJAN DIGO ESO CREO PERO ALGUIEN MAS PUEDE CONTESTAR ESA PREGUNTA YO TAMBIEN TENGO ESA MISMA PREGUNTA PARA LOS MAESTROS NIKK ERROR CHINO ERNESTO JAVI PARA TODOS QUEDA ESA PREGUNTA AL AIRE ,,,,,,SALUDOS |
Silver Member Username: Rober2154Miami, Fl Usa Post Number: 434 Registered: Jun-06 | es cierto que el bin del 7 de diciembre esta funcionando sin freez para el Ultra. | ||
Silver Member Username: PoyitoPost Number: 586 Registered: Dec-07 | CLAUDIA DEJAME VER YO MIRE ALGO NUEVO PARA PANSAT 3500 MAS NO SE QUE FUE DEJAME VER Y REGRESO Y TE DIGO OK ,,,,,,SALUDOS |
New member Username: CmcastroPost Number: 7 Registered: Aug-07 | Gracias Poyito Yo tambien estoy tratando de leerlo todo haber si encuentro. |
Bronze Member Username: La_bambaPost Number: 16 Registered: Aug-07 | Hola, Alguien sabe que BIN funciona para el CW800? | ||
Bronze Member Username: AlpPost Number: 80 Registered: Dec-06 | Alguien sabe si algun bin viejo esta funcionando para viewsat ultra (sin freez)??? | ||
Silver Member Username: PoyitoPost Number: 587 Registered: Dec-07 | -New post- Hello, Here are the old Pansat bins which are confirmed working on Dishnetwork. I cannot verify BellExpressVu, so trying checking yourself and report back, if you can. Have Fun! Pansat 250SM : Download Bin Pansat 9200HD : Download Bin Pansat 9000HD : Download Bin Pansat 2800A : Download Bin Pansat 6000HXC : Download Bin Pansat 5000HXC : Download Bin Pansat 3500S/SD : Download Bin Pansat 2700A : Download Bin NOTE: THE FILE SERVER IS A BIT SLOW, SO PLEASE BE PATIENT! Thanks to Saboo for posting all working bins! PARA LOS QUE TENGAN PANSAT RESIVERS |
New member Username: CmcastroPost Number: 8 Registered: Aug-07 | encontre uno que dice que el 3500 funciona con el bin 343. Que te parece Poyito, intentamos?? | ||
New member Username: CmcastroPost Number: 9 Registered: Aug-07 | ohhh, gracias. | ||
Bronze Member Username: EsdmiguelPost Number: 51 Registered: Aug-07 | CUAL BIN FUNCIONA EN 2500-2700 PANSAT | ||
New member Username: CmcastroPost Number: 10 Registered: Aug-07 | ahhh los links no funcionan! | ||
Silver Member Username: PoyitoPost Number: 588 Registered: Dec-07 | Posted February 18th, 2008 04:28 PM IP -------------------------------------------------------------------------------- -New post- Pansat-C 2700 227v1 Tivo -------------------------------------------------------------------------------- DO NOT USE THIS BIN IF YOU HAVE A CONVERTED 2500-2700 RECEIVER!!!!!! For Our Beta Testers! New Fix for Clone 2700's and Originals. Please Set Default Keys after loading. download bin OJO SI POSTEO ESTO NO QUIERE DESIR QUE ES SEGURA LA DESCARGA OK SOLO POSTEO PARA QUE TENGAN UNA IDEA DE CUALES ESTAN TRABAJANDO ,,,,,, TODOS SON BINES VIEJOS A DEMAS SON POST DE OTROS FOROS GABACHOS ,,,,,,,,SALUDOS |
Silver Member Username: Rober2154Miami, Fl Usa Post Number: 435 Registered: Jun-06 | Lorena; A mi me esta funcionando el del 12-07, para Ultra |
Bronze Member Username: HenryviiiTexas USA Post Number: 71 Registered: Jul-06 | Reportando el bin 227 p pansat 2700 original trabajando al 100%. Saludos! |
Silver Member Username: PoyitoPost Number: 589 Registered: Dec-07 | CLAUDIA PERDON PERO NO SON LINKS ALGUIEN A QUI DIJO QUE NO POSTEARAN MAS LINK PERO SI GUSTAS TELO POSTEO NO ME IMPORTA SI ME REGAYAN JEJEJEJE AHI TE VA QUITALE UN PINTITO A .COM POR QUE NO MEDEJA PONER EL LINK ,,,,,,,SALUDOS http://crazyfta..com/ |
Bronze Member Username: AlpPost Number: 81 Registered: Dec-06 | Gracias Roberto | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 582 Registered: Jul-06 | HOLA A TODOS/ DE NUEVO CONFIRMANDO, FortecLifetimeUltra/clones bin -CS_227T Fri Dec 07, 2007 FUNCIONANDO |
Silver Member Username: Cesar10Tamaulipas Mexico Post Number: 150 Registered: Dec-06 | buenas Noches a todos. Reportando que mi Pansat 3500 funciona con el bin 343. una vez se me puso "scrambled or bad chanel" pero se restablecio la señal como en 10 segundos. Saludos |
Bronze Member Username: EsdmiguelPost Number: 52 Registered: Aug-07 | CARLOS AVELAR DONDE LO ENCUETRO ESTE BIN | ||
Silver Member Username: Rrios01Monterrey, N.L. Mexico Post Number: 409 Registered: Oct-06 | que onda raza, pues aqui leyendo que algunos receptores estan teniendo problemas, eso sin duda se debe a que hubo cambio de llaves en el provider 0106, algunos ftas si pudieron ha_cer el autorrol y otros no, al parecer como dice Pollito y algunos mas de ustedes hay bines viejos funcionando el bin 1.73 del cw600s premium al 100% en DN y Bev, ya lo estuve revisando mas de 40 minutos y no se congela, cuando lo encendi a las 6:00 pm CT, se tardo un minuto pero si se hizo el autorrol saludos a todos en especial a mi compadre ernesto, nikk mty, error, javi garza pollito, rexio mty mike huasausky, fernando de venezuela , etc etc |
Gold Member Username: JuanchoLa blanca nieve en los..., En las altas... BINDURABLE Post Number: 2248 Registered: Dec-06 | ha*ce unas 3 horas que sonic*view saco los fix, quien seguira?. creo que luego saldran mas bines. | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 583 Registered: Jul-06 | MIGUEL LEE ARRIBA EN EL POST DE JOSHUA A LAS 7:28 ALLY ESTA EL LINK | ||
New member Username: ElchivigonMexico, Distrito Fed... Mxico Post Number: 8 Registered: Nov-07 | Hola a Todos. Para Coolsat5000 y Coolsat4000 sirve algun Bin antiguo???...me estoy perdiendo Prison Break ja ja ja | ||
Silver Member Username: Rexio_mtyPost Number: 227 Registered: Oct-07 | Es lo bueno de guardar todos los bines en un archivo de su pc.... asi tendran menos problemas de acceso a la web... este es para los originales 2700A... X-87BL_071207_B75_227_api saludos y guarden sus fixes en una carpeta, como veran hay que recurrir a ellos, como veran nuevos ECM viejos fixes...jejeje |
Silver Member Username: ViancheMontreal, Quebec Canada Post Number: 484 Registered: Sep-06 | gracias poyito por tu respuesta ahora lo que no me acuerdo si en ese tiempo le poniamos las llaves y si debo apagar el autorol | ||
Silver Member Username: PoyitoPost Number: 590 Registered: Dec-07 | EL CHIVIGON DISEN LAS MALAS LENGUAS QUE EL 156 ESTA FUNSIONANDO AL 100% ,,,,,SUERTE Y SALUDOS |
Gold Member Username: Jorge_luisSentir gratitud y no e...Saludos mi b... Post Number: 1932 Registered: Jul-06 | reciclados del 07 dic 2007 para los convertidos 2500/2700 CS_227T_Lightning_100t_Series_serial.zip Jvvh_Leafs(BG)_227.zip pansat 2700a ORIGINAL x-87bl_071207_b75_227_api.zip CLONES de Pansat 2700a Pansat-C 2700 227v1 Tivo.zip pansat 2800a x-88bl_071207_437eubx_api.zip pansat 3500 X-05BL_071207_343_api nocard.zip pansat 250m x_250bl_071207_v552a.zip tambien estan funcionando los bines para los pansat de la fecha 24-Diciembre-2007 |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 584 Registered: Jul-06 | POYITO YO LO PROBE Y NO SIRVE... | ||
Gold Member Username: TetuscosmicusPost Number: 2656 Registered: Nov-06 | Como dice REXIO MTY guarden sus bins cuando hay una emergencia esta guardado para cuando se necesite...y no tienen esa molestia de buscarlos en los links.... SALUDOS RAZAAAAAAAAAAAAAAA..... |
Silver Member Username: Rexio_mtyPost Number: 228 Registered: Oct-07 | Miguel y a todos los que andan en busca de fixes., la mayoria de la raza los postea esta es en esta direccion es nuestro FILE donde mayormente los ponemos para que los bajen...revisa si el que buscas esta ahi... [link removed] saludos a la razitaaa |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 585 Registered: Jul-06 | MIGUEL/ O A QUIEN INTERECE, ESTA PAGINA NUNCA ESTA CONGESTIONADA Y TIENEN TODOS LOS BINES ANTERIORES DE VARIAS MARCAS, REGISTRARCE ES GRATIS... |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 586 Registered: Jul-06 | POYITO YA ABRIO BIN 156 PARA C00LSAT 5000 FUNCIONANDO AL 100% | ||
Silver Member Username: Rexio_mtyPost Number: 229 Registered: Oct-07 | ke habido mi hetor, que dice poyito con papas...felices por que se ve que DN no tiene nada nuevo baja la manga...y los cuentos de blacklist pues kien sabe si es real, tal vez ya tiene un sustituto.....que acaso hay algo que el dinero no pueda hac_er??? animo a todos y los veo mañana, hay que cenar algo rico... bike |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 587 Registered: Jul-06 | BIN 156 C00LSAT 4000/ 5000/ 6000/ UP 100% | ||
New member Username: ElchivigonMexico, Distrito Fed... Mxico Post Number: 9 Registered: Nov-07 | Gracias Poyito, Gracias Carlos Avelar, Gracias Error. Entonces no me queda mas que esperar los de Cool y decirle a mi primo con PanSt me grabe el final de temporada... ja ja ja | ||
Gold Member Username: TetuscosmicusPost Number: 2657 Registered: Nov-06 | Es bueno leer antes de preguntar... porque es casi seguro que la respuesta ya esta en los post anteriores... Solo es de dar un ojaso mis amigos no se toma ni 5 minutos y es posible que vea la respuesta..... saludos a todos.... ARRIIIVVVAAAAAAAAAAAA LA RAZZAAAAAAAAAAAA.... |
Gold Member Username: NadadesatPost Number: 3636 Registered: Jun-07 | RINGGGGGGGGGGGGGGGGGGGGGGG. --HI ERNEST. --HELLO BOSS. --- WHAT'S UP ERNEST? --- NOTHING BOSS. ----OK. ----ENTONCES PARA QUE ME HABLAS ERNEST, PUES NOMAS PARA DARLE LAS GRACIAS. ---- DE QUE ERNEST?. --- ES QUE USTED NUNCA ME DEJA EN MAL, LAS CAPTIVE SIGUEN IGUAL NO SE CAYERON. --- HAY ERNEST, ES QUE TU SABES QUE ESTAN HECHAS DE FIERRO Y MADERA BUENA. --- BOSS ? --- QUE PASO ERNEST? --- THANKS. --- HAY ERNEST TU SABES QUE VA A PASAR PARA QUE ME DAS LAS GRACIAS. ----ERNEST, YA TIENES LOS BINES? ---- YA LOS ESTOY TERMINANDO. ----JAJAAJAJAJAJAJAJAJA ---- DE QUE TE RIES ERNEST. ---DE QUE ESTAMOS PREPARADOS CONTRA TODO. -- BYE BOSS. --- BYE ERNEST. |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 588 Registered: Jul-06 | CHIVIGON INSTALA EL 156 QUE TRABAJA MUY BIEN... | ||
New member Username: ElchivigonMexico, Distrito Fed... Mxico Post Number: 10 Registered: Nov-07 | Ah, entonces si el 156? Gracias a todos, ahorita lo busco y lo pongo | ||
Gold Member Username: NadadesatPost Number: 3638 Registered: Jun-07 | SALUDOS A MI COMPADRE EL CHINO Y A EDUARDO RIVERA DE GUTEMALA. | ||
New member Username: JecPost Number: 5 Registered: Jan-08 | REXIO MTY ME PUEDES MANDAR POR FABOR EL BIN 227 TENGO TODOS MENOS ESE. EL MAIL ES JCAVAZOS07@HOTMAIL.COM GRACIA SALUDOS |
Bronze Member Username: LociriSan nicolas de los garza, Nuevo leon Post Number: 23 Registered: Jan-08 | Reportando pansat 2700a original tardo un poco en abrir la señal, pero funciona al 100% Saludos foro |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 589 Registered: Jul-06 | ERNESTO, QUE ONDAS? DALE MIS SALUDOS A TU BOSS, DE SU AMIGO HUGO BOSS//// | ||
Gold Member Username: TetuscosmicusPost Number: 2659 Registered: Nov-06 | Saludos mi rexio mty... cuidate mucho...asta luego.. SALUDOS RAZAAAAAAAAA..... |
Silver Member Username: Rexio_mtyPost Number: 230 Registered: Oct-07 | Rinnngggggg rinnngggggggggg Rinnnggggggggggg Ringggggggggg |
Gold Member Username: NadadesatPost Number: 3639 Registered: Jun-07 | KATALINA AVILA LA GUIA PARA PROGRAMAR EL CAPTIVE ES CORRECTA. LO QUE PASA ES QUE TU LE HABIAS METIDO UN ARCHIVO EXTRA. SE LOS REPITO LAS CAPTIVES REGULAR Y LA PREMIUM, QUE SON LAS MAS POPULARES, ESAS NOMAS PARA PROFRAMARLA SE USAN DOS PROGRAMAS: 1.- EL LOADER VI.07. 2.- EL ULTIMO BIN. AHORA BIEN, KATALINA YO TE DIJE QUE LE METIERAS EL BIN DE FABRICA EL VI.09 Y DESPUES EL ULTIMO BIN Y SIGUIERAS LOS PASOS, PERO NO SE SI LO HICICISTE. PERO BUENO MI COMPADRE EL CHINO Y EDUARDO RIVERA YA TE DIJERON LA SOLUCION. HAY QUE CLONARLA. SALUDOS. |
Silver Member Username: Rexio_mtyPost Number: 231 Registered: Oct-07 | Locatel buenas noches , en que le puedo ayudar.. Buenas noches señorita..estoy buscando a una persona ahhh si digame el nombre por favor.. se llama eladio.... dejem ver un momento.... señor fijeses que no se encuentra, desde que llegaron los fixes pues ya no sabemos de el, al parecer se corto las venas ... bueno, gracias señorita.. de nada joven... llamada de hace 2 minutos.. si alguien encuentra a eladio avisenle que lo estamos esperano aki en el forum..jejeje |
Gold Member Username: NadadesatPost Number: 3640 Registered: Jun-07 | YA ESTA MI CARLOS AVELAR. | ||
New member Username: JecPost Number: 6 Registered: Jan-08 | JARRIAGA SALUDOS BUEN AMIGO ESPERO TU MAIL. | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 590 Registered: Jul-06 | REXIO/ ELADIO SE ASUSTO POR LO ULTIMO QUE LE DIJE, TIENE MIEDO DE ENTRAR EN EL FORO, YO LO ESTOY ESPERANDO PORQUE TENGO UN PAR DE PREGUNTAS QUE LE QUIERO H@CER, PERO CREO QUE NO CONSIGUE QUE LA HERMANA LE PRESTE LA COMPU.... | ||
Silver Member Username: Rexio_mtyPost Number: 232 Registered: Oct-07 | va en camino Jose cavazos....checa tu email.. | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 592 Registered: Jul-06 | REPITIENDO PARA LOS QUE RECIEN ENTRAN, Y NO LEEN... BIN 156 C00LSAT 4000/ 5000/ 6000/ UP 100% |
Gold Member Username: NadadesatPost Number: 3641 Registered: Jun-07 | RINGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG RINGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG -- QUE PASA ERNEST? ---BOSS HAY UN AMIGO QUE LE MANDA SALUDOS, SE LLAMA CARLOS AVELAR ES BUEN AMIGO. --- Y QUE ES DE CONFIANZA? --- JEFE NO ME INSULTE, CUANDO DIGO QUE ES AMIGO VA IMPLICITA LA CONFIANZA. --- EXCUSE ME, ERNEST. --- BUENO SALUDAME A CARLOS AVELAR. --- BOSS EN LOS FOROS ANDAN CORE Y CORRE POR LOS BINES. --- SI PERO LOS BINES DE CAPTIVE SIGUEN IGUAL Y TU YA LOS DEBES DE TENER, POR SI PASA ALGO. ---- BOSS, PUES PORKE CREE QUE ANDO AUSENTE, LOS ANDO PREPARANDO. JAJAJAJA ERNEST. --- BOSS? WHAT ERNEST? --- NO SE LLEVADO, ESA RISA NOMAS LA HAGO YO. -- EXCUSE ME ERNEST. --PERDONADO QUE NO SE VUELVA A REPETIR, SI NO ME CAMBIO DE EQUIPO Y YA QUIERO MAS MONEY. --- MAS ERNEST? -- YES. --- ERNEST NO QUE TU ERAS ESPIRITUAL? --JAJAJAJAJA SI PERO TAMBIEN MI ESPOSA TIENE SUS GASTOS. --OK ERNEST. -- BOSS LES PUEDO DECIR QUE VA A PASAR A LOS AMIGOS DE ESTE FORO. -- TU SABES ERNEST. --BOSS LO ADMIRO. -- Y YO A TI ERNEST. -- ERNEST CUANDO VIENES OTRA VEZ A LAREDO? -- NO BOSS ESPERESE UNA SEMANA MAS, QUIERO DESCANSAR. --OK ERNEST, PERO LOS FIX TENLOS POR SI LAS DUDAS. -- OK BOSS. ---BYE BOSS --BYE ERNEST. -- BOSS. WHAT? -- MONEY. - - NO ESTES CHIN.... JAJAJAJAAJAJAJAJJAJAJA LLAMADA HACE UN MINUTO. |
Silver Member Username: Rrios01Monterrey, N.L. Mexico Post Number: 411 Registered: Oct-06 | saludos compadrito ernesto al rato nos leemos porque me voy a cenar y luego a programar un cw600 que tengo que entregar mañana seguimos en contacto |
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 593 Registered: Jul-06 | GRACIAS POR LOS SALUDOS MI AMIGAZO ERNESTO... | ||
Bronze Member Username: EsdmiguelPost Number: 53 Registered: Aug-07 | carlos gracias ya tengo 2700 up pero tengo un vs tambien y es no trabaja no hay nada para vs | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 594 Registered: Jul-06 | PARA EL VS TE LO DEBO, TALVEZ ALGUN AMIGO EN EL FORO QUE YA ALLA PROBADO INFORMA AL RATO, MANTENTE ALERTA...SALUDOS | ||
Bronze Member Username: Luckas25Eagle pass, Texas Usa Post Number: 55 Registered: Sep-06 | alguien sabe de donde pudo bajar el bin para el viewsat ultra?? cual bin esta funcionando??? de dodne lo puedo bajar?? |
Gold Member Username: NadadesatPost Number: 3642 Registered: Jun-07 | YA ESTA COMPADRE CHINO USTED LOS PROGRAMA CON LOS OJOS CERRADOS Y SIN PROBLEMA. ARRIBAAAAAAAAAAAAAAAAAAA LA CAPTIVEEEEEEEEEEEEEEE WORKSSSSSSSSSSSSSSSSSS. LA NUMERO UNO Y LA MEJOR. |
Bronze Member Username: ElchivigonMexico, Distrito Fed... Mxico Post Number: 13 Registered: Nov-07 | Gracias Carlos. Ya estoy viendo el Season Finale en Denver!!! | ||
Silver Member Username: Miami1130Post Number: 499 Registered: Jul-06 | BUENAS NOCHES A TODOS,YA ESTAN SALIENDO LOS NUEVOS BINES DE SONICVIEW,SIN DUDA ESTA MARCA ESTA DANDO TREMENDO SOPORTE Y HOY POR HOY ES LA MARCA QUE PRIMERO ESTA SACANDO LOS ARREGLOS.(Y QUE CONSTE QUE NO TENGO SONICVIEW)PERO ES LA VERDAD. | ||
Gold Member Username: NadadesatPost Number: 3643 Registered: Jun-07 | YA ESTA MI CARLOS AVELAR, VEO QUE ANDA EN BIEN MOVIDO AYUDANDO A LA RAZA. | ||
Silver Member Username: Rober2154Miami, Fl Usa Post Number: 436 Registered: Jun-06 | juan manuel usa el del 12-7 | ||
Silver Member Username: PoyitoPost Number: 591 Registered: Dec-07 | REPORTANDO EL C00LSAT6100 TRABAJANDO AL 100% CON EL NORW_V127 ,,,SALUDOS | ||
Gold Member Username: NadadesatPost Number: 3644 Registered: Jun-07 | LA CAPTIVE WORKS NI SIQUIERA SINTIO EL ECM, SIGUE TRABAJANDO CON LOS MISMOS BINES. SALUDOS. |
Silver Member Username: Joel_eduardoTamaulipas Mexico Post Number: 129 Registered: Nov-06 | Hola amigos, la cuestion de mandar un EMC y solucionarlo con bin's viejos puede tener dos lecturas: Primero: puede obedecer en realidad a cuestiones tecnicas ( en este caso de programacion). Segundo: DN puede estar haciendolo a proposito con la finalidad de que al encontrar la solucion con bin's viejos, todo mundo quiera tener una especie de base de datos personal con bines viejos en su pc. Y se preguntaran , que con esto? Bueno, pues no tendria nada de malo si nuestra computadora la usaramos solo nosotros, pero puede darse el caso que el FBI aleatoriamente hiciera algun telnet a cualkiera de los muchos usuarios (ip's)que saben que "testeamos" con FTA's y pss ya sabran las consecuecias. Estarian en condiciones de tomar el control de nuestra computadora de manera remota (si es que no lo tienen ya)y de emprender acciones legales al encontrar contenido en nuestro equipo que demostraria que algun usuario en este supuesto caso, estaria realizando actividades ilicitas (pirateo) Lo mejor seria, (segun yo) que aunque la solucion a un EMC sea un bin viejito lo busquemos en cualquiera de los foros registrados, y que nos deshagamos de el en cuanto lo usemos. Por ultimo quiero decirles, que no es mi intencion espantarlos, pero si alguno de ustedes se siente "acalambrado" ps pongase mejor a ver television, despues de todo por eso estamos aqui arriesgandonos, no?. (no se me espanten ) (somos muchos) (ademas que tanto es tantito eh? ) |
Bronze Member Username: Paneca05Post Number: 32 Registered: Jan-08 | amigos algo para sonicview? | ||
Bronze Member Username: AlineerodrigoPost Number: 23 Registered: Oct-07 | cual o bin p/ vortex 3500 esta trabajado? | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 596 Registered: Jul-06 | MI ERNESTO/ HOY EN CANADA ES EL DIA DE LA FAMILIA, QUER MAS PODEMOS H@CAER?... | ||
Bronze Member Username: LociriSan nicolas de los garza, Nuevo leon Post Number: 25 Registered: Jan-08 | Pepe Cavazos te lo envie hace rato saludos | ||
Bronze Member Username: AndrilgPost Number: 35 Registered: Jan-08 | Alguien me puede decir como funciona dish y bev en un vs ultra, si tengo que cargar los dos bin o si existe uno para los dos | ||
Silver Member Username: Rexio_mtyPost Number: 233 Registered: Oct-07 | Jose cava, revisa tu correo man.. wueno nos vemos mañana... saludos Ernest Be good boy...si no le digo a tu BOSS que no te compre tekila japones..jeje |
Silver Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 403 Registered: Oct-07 | Andrilg Diaz: El mismo bin funciona para los dos. Saludos |
Gold Member Username: JuanchoLa blanca nieve en los..., En las altas... BINDURABLE Post Number: 2249 Registered: Dec-06 | joel eduardo, y estarias limpiando tu pc despues de usar los bines con un especial software para que no quede rastro del bin?. eso es ser paranoic, porque si no lo ha*ces asi ellos encontraran todo en tu disco duro. ademas que va a ha*cer el fbi en mexico, mejor cuidate de los locales y disfruta TV, solamente ten cuidado cuando abras la puerta ,puede ser el fbi...lol. y ahora como te deshaceras del post donde admites que estas ha*ciendo algo ilicito, porque en este foro tienen tu ip, y talvez alguien que es del fbi esta leyendo tu post, algunos post permanecen y estan posteados en la web para que el que quiera puede leerlos, mios han sacado algunos de ellos, los veo cuando investigando algo en la web for google... asi es que mejor a destapar unas pico de oro, salud.... |
Gold Member Username: Jorge_luisSentir gratitud y no e...Saludos mi b... Post Number: 1933 Registered: Jul-06 | Ernesto si que sabe divertirse me da gusto su buen humor |
Silver Member Username: PoyitoPost Number: 592 Registered: Dec-07 | JOEL EDUARDO JUAN RAMIREZONE NO SE LI LEISTE POR ALLI QUE ALGUIEN POSTEO QUE EL FBI ISO UNA REDADA ,,,,,, PERO NO MENSIONARON SI LA REDADA FUE PARA LOS VENDEDORES DE CAJAS DEALERS O PARA LOS QUE ESTAMOS USANDO LAS CAJAS ,,,SALUDOS |
Silver Member Username: Miami1130Post Number: 500 Registered: Jul-06 | MIS FELICITACIONES ERNESTO,POR ESA GRAN CAJA Q TIENES Q SOPORTO EL ECM.MIS SALUDOS A TI.ESTOY DE ACUERDO CON RAMIREZONE WOW ESO DEL FBI Q DIJERON ESTA DURO ESO(LAS PELICULAS NOS HASEN DAYO A VECES)EL FBI EN ESTE PAIS TIENE TANTAS COSAS QUE HASER Q NO PERDERIA TIEMPO EN ESTA ESTUPIDEZ Q SOLAMENTE TIENE Q RESOLVER DN COMO HIZO DIRECTV Q RESOLVIO SU PROBLEMA ELLOS MISMO. | ||
Gold Member Username: Jorge_luisSentir gratitud y no e...Saludos mi b... Post Number: 1934 Registered: Jul-06 | no se confien jejejeje saludos...... |
New member Username: JecPost Number: 7 Registered: Jan-08 | GRACIAS REXIO Y JARRIAGA YA ATERIZO SALUDOS COMPAYEROS | ||
Bronze Member Username: YiperPost Number: 27 Registered: Dec-07 | ey k roio razaaaa ke habidooo??? ei ernesto cual esta funcionando para la captive regular akabo d iegar i apenas ando chekando |
Bronze Member Username: Paneca05Post Number: 33 Registered: Jan-08 | sonicview esta trabajando o esta down? | ||
Silver Member Username: PoyitoPost Number: 594 Registered: Dec-07 | A DEMAS EL FBI ANDA DE TRAS DE GENTE QUE ESTA ASIENDO COSAS ILEGALES MILLONARIAS O MATANDO GENTE PODEROSA O BUSCANDO GENTE QUE LE ASE DAYO AL PAIZ ELLOS NO BAN A IR A TU CASA POR QUE TE ESTAS ROBANDO LA SEYAL PARA VER PELICULAS Y ANUNSIOS QUE GRASIAS A LOS ANUNSIOS COMPRAMOS LOS PRODUCTOS ASI QUE PARA MI LES COMBIENE QUE TU TENGAS TELE GRATIS Y CONSUMAS DE ALGUNA MANERA LOS PRODUCTOS QUE SE ANUNSIA AHI HUMILDEMENTE LA OPINION DE POYITO ,,,,,SALUDOS | ||
Silver Member Username: PoyitoPost Number: 595 Registered: Dec-07 | ERROR SALISTE MUY BIEN EN ESA FOTO Y ESA ID TE QUEDO MUY BIEN JEJEJEJE ,,,SALUDOS MI BUEN AMIGO ERROR |
Silver Member Username: Miami1130Post Number: 501 Registered: Jul-06 | LA VENTA DE CAJA ES LEGAL AQUI EN USA,Q LA COJAN PARA OTRO USO ES OTRA COSA Y LOS DEALER NO SE RESPONSABILISAN POR ESO. | ||
Silver Member Username: Miami1130Post Number: 502 Registered: Jul-06 | POYITO MIS SALUDOS,ES CIERTO LO QUE DICES ESTO PARA EL FBI ES COSA Q NI LE INTERESA,AHORA COJER UN PEZ GORDO ES OTRA COSA,ALGUIEN QUE TENGA 300 CAJAS EN LA CASA Y SE DEDIQUE A ESO,Y COSAS GRANDES Y CON TODO ESO ES POLICIA NO FBI.PERO NOSOTROS QUE TENEMOS 1 O 2 CAJITAS Y BAJAMOS FREE EN INTERNET LOS PROGRAMAS HAY POR FAVOR ESTAMOS EN ESTADOS UNIDOS. | ||
Bronze Member Username: YiperPost Number: 28 Registered: Dec-07 | ei poyito io pienso masomenos como tu especulo algo debe de tener de negocio esto para fish de cierta forma... si no hace mucho que hubieran cambiado su tecnologia... algo si puedo decir nadie sabe para quien trabaja... ni ernesto... jaja naaa no se krea ernesto es puro cotorreo |
Silver Member Username: PoyitoPost Number: 596 Registered: Dec-07 | UNA PREGUNTA CUANTO TIEMPO TIENE ESTO DE LAS CAJAS FTA??? | ||
Silver Member Username: Miami1130Post Number: 503 Registered: Jul-06 | 5 AYOS CREO MAS O MENOS,SINO QUE ME RECTIFIQUEN | ||
Silver Member Username: PoyitoPost Number: 597 Registered: Dec-07 | VES EN CINCO AYOS CUANTA GENTE ESTUVERA PRESA EN EL BOTE CARCEL JEJEJEJE TE DAS CUENTA YO ME ACABO DE REGISTRAR EN UNA PAGINA PARA BAJAR BINS Y YO FUI EL USUARIO 73,458 TE DAS CUENTA Y ESO SOLO EN UNA PURA PAGINA AHORA BUSCA CUANTAS PAGINAS ESTAS EN LA WEB REFERENTE A FTA ?? CUANTOS USUARIOS CRES QUE AVEMOS POR TODOS ?? TU CRES QUE SI FUERA FACIL PARA EL FBI NO UVIERA PAGINAS TAN ALA VISTA DE TODOS ESTUVERAN MAS PRIVADAS ME ENTIENDES AHORA QUE SI AGARRAN A ALGUIEN ES POR QUE EL VESINO LE PUSO EL DEDO CON LA POLICIA JEJEJEJE SALUDOS | ||
Gold Member Username: JohnnerMiami, Florida Post Number: 1533 Registered: Nov-05 | |||
Silver Member Username: NeoxTijuana, Baja California Mexico Post Number: 175 Registered: Aug-06 | piensen como gente madura gracias | ||
Silver Member Username: PoyitoPost Number: 598 Registered: Dec-07 | A DEMAS CADA OPERACION DEL FBI O LA POLICIA LOCAL LES CUESTA UNA LANA AL DEPARTAMENTO DE LA MISMA Y SI ME AGARRAN AMI QUE ME PUEDAN SACAR ??? METERME AL BOTE Y DARME DE COMER ALLI JEJEJEJE POR QUE DINERO DE DONDE CHINGADOS SI APENAS TIENE UNO PARA LA PINCHE RENTA POR ESO NO TENGO CONTRATO CON DN NI CON DTV JEJEJEJE PERO SI PARA FTA FREE OFF AIR JAJAJAJA ,,,,,,,,,SALUDOS | ||
Silver Member Username: AnaiTX United States Post Number: 218 Registered: Jun-05 | SONICVIEW 4000 acaba de salir un bin 212 para charlie y bev alguien sabe algo de esto, esta informacion la acabo de encontrar en FTATALK????? |
Bronze Member Username: MarioandresPost Number: 85 Registered: Apr-07 | YO PIENSO QUE MIENTRAS UNO CAPTE LA SEYAL SOLO PARA UNO MISMO Y NO LA DISTRIBUYA O LA VENDA ,NO HAY PROBLEMA O EL PROBLEMA NO ESTAN GRAVE ES MI OPINION | ||
Silver Member Username: CavelarWOODBRIDGE, Ontario CANADA Post Number: 597 Registered: Jul-06 | AMIGOS / NO CREAN EN SANTOS QUE ORINAN, ESO DEL FBI ES PARA LAS NOVELAS, DRISFRUTEN DE FTA FREE... | ||
New member Username: JecPost Number: 8 Registered: Jan-08 | ERNESTO CUANTO VALE UN CAPTIVE W 600 PREMIUM SALUDOS. | ||
New member Username: CabrahamMonterrey, Nuevo Leon Gpe Post Number: 7 Registered: Feb-08 | que onda raza saben con que bin esta funcionando el CWPREMIUM? | ||
Silver Member Username: PoyitoPost Number: 599 Registered: Dec-07 | A DEMAS UNA COSA SI LES BOY A DESIR TODAS LAS COMPANIAS DE SATELITE Y CABLE DEL MUNDO GANAN UN CHINGO DE BILLETES POR LOS ANUNSIANTES Y LOS QUE PAGAN POR PASAR SUS PELICULAS NOVELAS DEPORTES Y MAS COSAS Y SEME ASE INJUSTO QUE AUN ASI LOS PAQUETES ESTEN TAN CAROS MUY CAROS POR QUE NO PONEN UN PAQUETE COMO EL QUE TENEMOS CON FTA POR UNOS 20 DOLARES AL MES Y PARA OTROS PAISES EL EQUIVALENTE ,,,,,,,, ASI NADIE TUVERA EL GRAN PROBLEMA DE TENER TV FREE JEJEJEJE PROBLEMA JEJEJEJE ,,,,,,,,,,SALUDOS Y ADISFRUTAR DE TELE Y ARRIVA LOS PUMAS QUE POR FIN GANARON PUMAS_______4 JAGUARES____1 SALUDOS |
Silver Member Username: FerhenMaracaibo, Zulia Venezuela Post Number: 105 Registered: Jul-07 | Pues mis amigos...yo sufriendo porque tengo dias sin poder ver el 119...ya de veras casi me doy por vencido....desde que salieron estos ultimos bines nada que ver....pero si veo otros satelites como el Amazonas e Hispasat.... Saludos! |
Bronze Member Username: MarioandresPost Number: 86 Registered: Apr-07 | ADEMAS ESA SEYAL INVAME MI PROPIEDAD ESTA EN LE TECHO EN EL PATIO EN EL BALCON SI ABRO MI VENTANA ENTRA EN MI ALCOBA YO NO HE EXTENDIDO UN CABLE PARA CANECTARME ILEGALMENTE LA SEYAL LLEGA HASTA MI EN ONDAS DE RADIO YO NO LA PEDI PERO AHI ESTA BOMBARDIANDONOS TODOS LOS DIAS |
