Kinetik? wtf
Username: Mendonmafia
Post Number: 1245
i just went to their web page and did the battery calculator and it says i should replace my existing battery with a hc 1400 and then buy 2 more hc 1400 to put in the trunk! should i really have that much battery power?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 680
how many watts r u running?
Post Number: 1246
nearly 3k rms between subs and amp for speakers
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2416
That seems about right. I was running 2 HC2000s with 2800rms.
Post Number: 1247
damn. i thought i didnt even need to exchange my stock battery.
Los Angeles, CA
Post Number: 18400
you don't have to but its good that you do.
Username: Nd4spd18
Northwest PA
Post Number: 6310
Don't listen to that calculator........ think about it, Kinetik telling you to buy a lot of kinetik batteries, what a surprise.
Replace your stock battery with the biggest one possible. DEFINITELY get an HO alternator if you don't have it yet, or nothing else is going to help.
Post Number: 1248
Alright thats what i was planning to do already. thanks M.S.
btw per your suggestion i went with the MCR 200 amp alt. should be here in a week or so (custom build, said it wasa 2 week job) i cant wait to install her :-)
Username: Nd4spd18
Northwest PA
Post Number: 6314
MCR makes strong alts........ that should do good, along with a good battery
Post Number: 1249
yea im gonna get a kinetik or yellow top once my current bat dies which should be soon. might even go ahead and buy it and just roll with it in my trunk incase it does die.
Username: Nd4spd18
Northwest PA
Post Number: 6321
Batteries get weaker slowly as they get old...... just put the new one in when you get it.........
Odyssey, Kinetik, or other car audio battery...... they are miles ahead of optima. Yellowtops especially, not ideal for car audio.
