Silver Member Username: DghummanOntario Canada Post Number: 205 Registered: Feb-06 | i want to install 118.7 but its not in my receivers list i have nfusion and viewsat pro if its not in the list how do u get in the list please help. also i have 121 big dish can i use that for 118.7 |
Silver Member Username: Madflea168Post Number: 268 Registered: Jan-08 | I dunno about nfusion, but with vs, you will need to modify it, several posts on this issue thru out the forum. people are suggesting by creating a new sat or use 119 or use 121 then add tp @11715 to it to scan. the settings are pretty much the same as 121. I did mine with add tp to 121 list, the other two methods did not work for me. you might need to move the antenna a little, I need to move mine too. good luck. |
Silver Member Username: DghummanOntario Canada Post Number: 206 Registered: Feb-06 | how do u get 118.7 if its not in the satellite list please clarify, i know i will have to move the dish a bit but how do put 118.7 in the satellite list n the receiver. |
Silver Member Username: DghummanOntario Canada Post Number: 208 Registered: Feb-06 | can someone please help me with this problem |
Bronze Member Username: FulaliPost Number: 33 Registered: Sep-06 | Please let me know how to add 118.7 on VS ultra satellite list. Thanks in advance |
Gold Member Username: NydasPost Number: 8256 Registered: Jun-06 | [link removed] |
Gold Member Username: NydasPost Number: 8257 Registered: Jun-06 | Daminder: It does not matter if it is in the sat list. Use Echo 9, and make sure that LNB freq is 10750. The appropriate LNB - you should use a "Universal" LNB and put that in as a setting. The first TP must be 11715. Remove all other frequencies and do a full scan or Blind scan. You can also scan individual TPs as listed under Anik3 (118.7) in http://www.lyngsat*com |
Gold Member Username: NydasPost Number: 8262 Registered: Jun-06 | Here is an interesting post from Cessna Pilot, a well know senior MOD at al7bar*tk. "For what it's worth, I am using a 1.2 meter (52") dish for the 118.8/119 Sat. For the heck of it, I also tried it on an 18" dish. It does work on an 18" dish, but the quality is poor, so any precipitation at all, and the signal drops rapidly. Use a larger dish if you can. The reason I am mentioning this is for those that wish to experiment and change their LNB on a single dish aimed at 119; it is an easy task to perform. If the LNB's LO is 10750, it still will receive both Anik 3 and Echo 7. I tried it and it does work. You just need to reconfigure your LNB's frequency to 10750 on Echo 7, in the antenna setup area." |
New member Username: SumairPost Number: 1 Registered: Feb-08 | Hi Nalin, Please advise if 227 or 332 is OK for Geniune Pansat 2700A |
Gold Member Username: NydasPost Number: 8269 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/450785.html |
Bronze Member Username: Lookekhoshshans_1356Tehran, Tehran Iran Post Number: 52 Registered: Apr-07 | https://www.ecoustics.com/electronics/forum/home-video/446436.html you can go and get 118.7W |
Silver Member Username: BirdwatcherPost Number: 691 Registered: Jul-06 | why do you want 118 anyway. is it because of al jazir. |
