double check port setting... or every thing is connected back to dish properly... try to put the same lnb again.. and then check signals again... may be move your lnb a bit or something...
not rite now sada its 8:00pm 2morro and here is my setting
Sat -- 119 Freq- 12239 LNB Power -on LNB Type- universal LNB Freq-10750 LNB 22KHZ - ???? DiSEqC port 2 Legacy SW - sw44 dish2 also tried none Level is 32% Quality is 0%
Sat -- 118 aka 121 Freq- 11715 LNB Power -on LNB Type- standard LNB Freq-10750 LNB 22KHZ - off DiSEqC port 2 Legacy SW - none Level is 12% Quality is 0%
Hey Smart1 Yo have a minor pointing issue Turn on beep option on your receiver From Menu>>>User Setting>>>Option>>>set Beep on With receiver off Run a straight coax cable no switch from LNB to receiver Start with Sat 119 at tp freq 12239 Slightly Ajust dish left, right up and down As yo hear beep yo'll get better quality No blind scan
If no luck try 110 at tp freq 12239
Do one sat at a time
If still no luck Then try to manually insert 1Tp at a time slightly adust dish for strong beep and good Q level and then chan scan Never use blind scan
Finally, do an AUTO SCAN or a BLIND SCAN **--- **--- **--- **--- **--- **--- **--- Why are you using Port 2 - maybe try Port 1? Note that the first Freq of 118.7 is 11715 Vertical. You may have to enter this manually, by deleting ALL the TPs and then entering just one TP. Initially do not have anything else connected except this.
If everything else fails, You can also try entering all the TPs of 118.7 from Lyngsst and then do individual TP scan of each TP.
W: It is late night now. Sada or Smart 1 might be able to help. I will look at the situation tomorrow. You have to post the details of your Dish, LNBs receiver, etc.
probably need to do a minor antenna adjustment, in order to get 118, you will need to get strong 119 first. worry about the setting on 118 later, try to get 119 is your priority.
ok i just got the new DGL-1189S and cant seem to get the signals
Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button I got more than 200 chanells
W first you will need to buy (1) LNB DGL-1189s and (1) two holder bracket. Put the new LNB in the center & the existing LNB for 121 to the side of the bracket. For more info. read this thread.
$mart1 I gave yo the answer If yo got no Q level no matter what yo do won't get channels Your settings look alright Adjust your dish like I told yo in post#2373 Come back and tell me how it worked
ok so i moved the lnb up and down but no luck.....i tried my old one and im not getting 119 with that one.....king please help..i cant run the cable straight to the receiver...
Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button I got than302 active chanells
i tried every thing im getting 148/110 but not 119/118 i haven't tried moving it i tried to move the lnb and got 52 q but goes up and down (0 and 52 0,52) it just keeps going up and down.... wont stay at 52.....
$mart,instead of going round in circles try this first
King Tapeman Gold Member Username: Tapeman
New York City in-HD , NY
Post Number: 2373 Registered: Oct-06
Posted on Thursday, February 14, 2008 - 10:59 pm: Hey Smart1 Yo have a minor pointing issue Turn on beep option on your receiver From Menu>>>User Setting>>>Option>>>set Beep on With receiver off Run a straight coax cable no switch from LNB to receiver Start with Sat 119 at tp freq 12239 Slightly Ajust dish left, right up and down As yo hear beep yo'll get better quality No blind scan
ok I GOT A NEW LNB....So i can get 119/118.7 i already have 110/148 i changed the old lnb with a new lnb and now im not getting any quality i tried my old one and did not get anything...now i have the straight wire and im trying to move the dish left and right
Yesterday I bought the LNB which catch 118 & 119... I set everything as said here.. BUT STILL am doing ROCK And ROLL .. OUT IN ...OUT IN..Cheking DISH.. checking receiver.. .. STILL nothing playing... BUT we 'll have to be patient... we'll finish by getting it.. am sure.. COURAGe my friend.......
