Bronze Member Username: Sam2256Post Number: 12 Registered: Jan-08 | for the life of me i cant get this thing to program keep getting write failed using blacklist v14 null modem cable what the hell am i doing wrong any help would be appreciated |
Gold Member Username: NydasPost Number: 8241 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest Saif and Lothario_250, CS_250T and Jvvh BINs included. Also available separately in All_250.zip file The All_249-2.zip has all the 249 conversion files separately as well Some jtag files are also included. The full kit is in full_kit250D.zip or later. Download the kit and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file. http://public.box.net/2500_full_kit New ECM today. Use old BIN 232 or 227 |
Silver Member Username: BorinickPost Number: 295 Registered: Mar-07 | craig bowerman did you unzip the bin before loading it |
Bronze Member Username: Sam2256Post Number: 13 Registered: Jan-08 | i just download than extreact to pansat folder open blacklist select bin idont understand it looks like its unzipped please help nick and thanks |
Gold Member Username: NydasPost Number: 8245 Registered: Jun-06 | craig: There ARE NO shortcuts. Read the instructions properly. People have spent time creating the instructions, so you would not have to post questions. |
Bronze Member Username: Sam2256Post Number: 14 Registered: Jan-08 | read and followed to a tee is the cable i need ff null modem cable. my box has been converted from a flu to a pansat it was just working i take it somewhere and they do it i do the extreme myself with never no problems but this pansat no gowrite failed all thetime. is there a lock or something this guy can put on it so i cant do it myself. |
Gold Member Username: NydasPost Number: 8247 Registered: Jun-06 | If you look at the instructions, it says clearly that you have to use a straight DB9 cable - NOT a null modem cable. |
Bronze Member Username: Sam2256Post Number: 15 Registered: Jan-08 | is the straight db9 the same cable to do viewsats.i went over this thats was said on a previous post and i thought it was u who said null modem im probaly mistaken but somebody did im tryin to find post |
Silver Member Username: The_codersPost Number: 484 Registered: Jan-08 | NO - Viewsats use null |
Bronze Member Username: Sam2256Post Number: 16 Registered: Jan-08 | will a null adaptor work |
Silver Member Username: The_codersPost Number: 489 Registered: Jan-08 | "If you look at the instructions, it says clearly that you have to use a straight DB9 cable - NOT a null modem cable." |
Bronze Member Username: Sam2256Post Number: 17 Registered: Jan-08 | nalin said null adaptor would work i thought as he was god around here well enough said will get right cable |
