Hi everyone,,, need help with ariza 700 instalation...i have dish with dual LNB pointed to 61.5 DN///i would appreciate to get a latest loader/factory flash and bin file for ariza 700 for DN///THANKYOU
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 16 2008 ________________________________________ Enjoy everyone! I keep my word! Why because thats all I have! Have a great weekend.
MINGO><OGNIM Attached Files
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 16 2008.zip (1.66
Setup instruction Using a 30- inch larger dish aim withe the following for DGL - 1189s you should setup as below will better. Satelite 118W or 119W LNB Power ON LNB TYPE Universal LNB Freq 9750/10750MHZ Finally do an auto scan or a blind scan. 61.5° Lnb = On Lnb type = Universal Freq = 9750/10750MHZ 22khz = Off Diseqc = 3 Committed = OFF or NONE Legacy SW = Off
still no channels on my ariza 700///tried factory flash///latest bin///all the tp are scanned but can only scan one channel which says you are pointed to 61.///i dont know what else to do//anyone can help me plz
61.5° TP 12223(12224)(V) SR 20.000 LNB power ON LNB Type Standard Freq = 11250 22khz = Off Diseqc = 1... you have to put1,2or3 it is up to you. LEgacy SW NONE Positioner Setitting Disable
LNB Type If your Lnb Ocs-dp put Standard
And some Lnb type = Universal . you should know what kind LNB you have
