Bronze Member Username: May_queenPost Number: 13 Registered: Apr-07 | Just curious - Seems like the International channels are available on 119 as well. Is there really a need for keeping a separate dish for E3 61.5? Wouldn't it be more efficient to just use 110/119? Thanks for the insight that anyone can provide. |
Gold Member Username: NydasPost Number: 8222 Registered: Jun-06 | You are thinking in the right direction. 1. However the Dish for 118.7/119 is minimum 30" preferrably 33". Most people with 119W have a 20" oval Dish. 2. It is too cold to work on the roof right now!! |
Bronze Member Username: BernardmiPost Number: 68 Registered: Dec-07 | I am happy with E3 at 61.5. Live in Eastern Canada and my backyard forest located west of my house blocks everything below 85 degrees. E3 is just above my head and gives an exceptionally and extremely strong signal here. Isn't the E3 replacement satellite being mounted on a Proton rocket right now ? That is going to bring changes at 61.5 anyway !!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
New member Username: ThetaffeyPost Number: 9 Registered: Feb-08 | THIER ARE NO INTERNATIONS ON ECHO 7, thats ANIK F3 what ur talking about; |
New member Username: ThetaffeyPost Number: 10 Registered: Feb-08 | THIER ARE NO INTERNATIONALS ON ECHOSTAT 7, ONLY ON ANIK F3. |
Bronze Member Username: May_queenPost Number: 15 Registered: Apr-07 | I looked at the following: http://www.lyngsat*com/packages/dish119.html Seems like they include internationals here. I am not pointing to 119, so I can't verify. But lyngsat is generally accurate info. |
Bronze Member Username: ThetaffeyPost Number: 11 Registered: Feb-08 | Yes, but that also combines ANIK F3 , 118.7 |
