VS null cable question...
Username: Nub2fta
N/a, N/a Canada
Post Number: 131
I am replacing my computer, and the new one will not have the com ports like that I currently use, I would like to know what are my options??? VS Ultra uses usb... Is a usb to RS232/DB9 pinout a possible solution??? Also, seeing as loader 2 lists only com ports as a source, is there another loader that I should get???
Thanks for any input,
nub.
Username: Way2smart
Www.desifta.tk
Post Number: 1322
vs ultra has the flash drive so use that......faster then serial cable
Username: Nub2fta
N/a, N/a Canada
Post Number: 132
sorry, I was not clear. I have a Platinum & xtream so I do not have that choice of using a usb... I was thinking of getting a usb to DB9 cable to transfer files. but, I forsee issues with the software side of things because Loader2 does not list usb as an option.
Thanks,
nub.
Username: Way2smart
Www.desifta.tk
Post Number: 1323
yaa you can use it with loader 2.....but its really slow with the usb to serial
Username: Nub2fta
N/a, N/a Canada
Post Number: 133
small price to pay.... hey if it works, I'll take it, until I find better.
cheers,
nub.
Username: Kirankumar
Kenya
Post Number: 1649
keep your old desktop just for fta,it's not worth anything anyway
Username: Nydas
Post Number: 8293
Sometime I wish I had kept my old 386 desktop. Not just for the old hardware connections but for some of the older software.
Find a small space in the basement for your old receiver.
