I check the signal from sat 148 is 82% (using my other receiver) but when I connect the same antena wire into my sv4000, it dosn,t show any signal and quality.Tried to switch tps.doesn,t help.Same way when I put antena wire coming from sat119, into my sv4000 show signal and quality both even tv but antena wire from sat148 with 82 % signal show nothing.
put ur port setting from your sonic view menu and ur other rec.. here.. go to menu inst and what ever it says put it here.. or just comparet the two and if u see a difference make it same... or just post it here and i will see.. i believe the other rec you are talking about is also fta rec like viewsat etc...
SADA,,, thank you for help. my other one rec is same sv4k. I match setting on menu and inst section. But sada it is really strange 119 was working fine with (old) wrong setting but not 148. Please answer me if you by chance know why. Otherwise please accept my thanks.
I'm using dn's duel.RC ..my problem was solved by matching setting with my other rece. But it was strange 119 was working with what ever setting I had before matching.But 148 wasn't.Anyway, thanks
