Need help w/ big 3
Username: Evoixmr
Post Number: 133
I've upgraded the alt => batt, and battery ground, can't find a wire on my car that grounds the engine to chassis. Is it an existing wire, where do all of you hook it up? I'm also just running 4 gauge in addition to the existing 4 gauge. Does 4gauge + 4gauge = 0gauge?
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2158
it isnt an existing wire. find any bolt that goes into your engine block and put a wire there and put the other end of the wire either to - batt or some bar metal on the frame of the vehical.
As for the wire i would do 2 lengths of 4awg that way its the equivilant of the stock wire plus a 1/0 wire.
for my engine ground i put a wire where i securedd the alt to the engine becuase it was right on the block then the other end to - batt
Username: Snarl2004
Post Number: 2159
hope this clears some things up
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1468
KLM? nice
Username: Snarl2004
Post Number: 2160
mhmm i love it flexible copper wire yet beefy
Username: Evoixmr
Post Number: 138
thanks, snarl. Any ideas for adaptors to hook up that much 0gauge to my battery.
pic of my battery.
the grey 0 gauge goes to the amp and the red 4gauge goes to the alt.
[IMG]http://i273.photobucket.com/albums/jj236/evoIX719/final044.jpg[/IMG]
Username: Evoixmr
Post Number: 139
do you ground engine to chassis or engine to battery?
Username: Snarl2004
Post Number: 2161
dunno about how to hook it up to the battery i guess use your imagination there lol
well your battery is grounded to chassis so you can ground engine to - battery or chassis which ever you want.
Username: Waresgaragestereo
Fort Valley, GA United States
Post Number: 141
"I'm also just running 4 gauge in addition to the existing 4 gauge. Does 4gauge + 4gauge = 0gauge?" I doubt it. I'd use 1 1/0 all the way for all of the big 3.
M.S,
Am I correct?
Username: Th3pwn3r
Post Number:...
Post Number: 6856
Using 1/0 awg wire would be wise as long as you're going to use the wire's capabilities. It's a good idea to use in the first place in case you ever wanted to upgrade for example from 1,000watts RMS to 2,500 watts RMS. You wouldn't need to replace the wires you did your "Big 3" with again.
Alt to battery postive
Engine to Chassis(Alt case works just fine as it is attached to the engine block)
Battery Negative to Chassis
Sure you can run a ground from your engine to ground at your battery but why would you run that wire over to your battery? It all ends up going to the same place anyhow and that is your chassis. Snarl Knukonceptz wire is aluminum not copper or is the KLM all copper? Not that it's that big of a difference but my Kolossus Kable is aluminum so...I'm just wondering.
Post Number: 1471
its 90% aluminum and 10% copper i think.
Username: Th3pwn3r
Post Number:...
Post Number: 6867
^Right. The aluminum being the inner layer and copper being the outer.
Username: Th3pwn3r
Post Number:...
Post Number: 6868
Or something like that =/ Maybe it's copper tinned aluminum.
Username: Kd7nfr
Moody AFB, GA United States
Post Number: 1802
The engine to chassis has always made me scratch my head. The alternator is electrically coupled to the engine...
And "most" are usually already grounded via engine mounts (depends on the car though).
Username: Snarl2004
Post Number: 2175
my klm wire is either copper tinted or copper. no aluminum. but im almost positive it says copper wire on the wire.
Username: Imback2500
Post Number: 88
snarl ur wire is chit u aint got no copper wire
ur a liar....i can never beleive you
u always lie
Username: Philly306
I get higher golf scor..., North carolina
Post Number: 875
Not Reece^^^^^^
check sn its the f@g again
Username: Snarl2004
Post Number: 2176
ya i know but he amuses me so i dont mind
Post Number: 101
im glad i amuse you
lmao u amuse me my new name nex time willbe the jackal
cause i can be every1
Username: Evoixmr
Post Number: 144
"Using 1/0 awg wire would be wise as long as you're going to use the wire's capabilities. It's a good idea to use in the first place in case you ever wanted to upgrade for example from 1,000watts RMS to 2,500 watts RMS. You wouldn't need to replace the wires you did your "Big 3" with again."
I've decided to redo everything with 0 gauge.
To hook the wire up is it ok to use the normal ring terminals w/ the set screw, or do I need the compression type.
Username: Evoixmr
Post Number: 145
Also would it be wise to get an optima batt, now that everything else in my charging system is upgraded?
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 4199
get a deka 9a34
Username: Evoixmr
Post Number: 146
Its a little to big, these are the dimensions I need:
length-9"
width-7"
height-7"
needs to have top and side posts
