Install guidance pansat 3500sd
Username: Tasmanian_satellite
Post Number: 21
I have a spare dish and i would like to aim it to receive dn. Since bev is down i would like to do this what do i need to do with my receiver?? What would the elevation be with the dish and which direction do i have to point it..All advice is greatly appreciated.
Username: Dimwitt
Post Number: 421
do your antenna settings for the sat you want(lnb type and diseqc port)
use this site
www.dishpointer.com
set the map to your dish location, select sat you want , aim as shown and adjust elevation till you get good quality
Post Number: 22
thanks
Post Number: 23
what satellite would be dn.is it 110w 119w
