Gold Member Username: Skibum12189Cleveland Post Number: 2607 Registered: Mar-06 | 15" TC-3000 DVC Qts 0.407 Qes 0.431 Qms 7.30 Fs 22hz Res 4.23Ω Ls 6.1 mH Lp 13.8mH Rp 17.38Ω Dia 325mm Vas 146l mms 365g cms 135um/N bl 22.6T*m Spl 87.7dB Should I go ported or sealed?? I've heard it'll slam either way, but the sealed box should be almost 2.5^3??? |
Gold Member Username: Skibum12189Cleveland Post Number: 2608 Registered: Mar-06 | more than anything, i want it to sound clean....if necessary, ill go ported, but i want to maximize sq....i guess i just want it to sound real clean and get loud....(run off a DD M1) |
Gold Member Username: Skibum12189Cleveland Post Number: 2609 Registered: Mar-06 | BTW http://www.audiopulse.com/products/subwoofer-drivers/axis/ BTW, the Audiopulse Axis is apparently very similar to the 3k.... |
Silver Member Username: MateoPost Number: 264 Registered: Oct-05 | personally, id port it, but pure SQ isnt really for me, i had a set of G5s, and LOVED the SQ, but jsut wanted something more...im putting my 15" Titanium in a T-line....but if you like SQ id say seal her up |
Gold Member Username: Spivey17323Dunellen, New jersey United states Post Number: 1137 Registered: Jun-07 | port that bish |
Bronze Member Username: Alex_smithPost Number: 53 Registered: Sep-07 | i think with that sub you can maintain nice sq with with a ported box. if you tuned around 32hz you should still be happy with the quality. thats what i would do |
Silver Member Username: MateoPost Number: 265 Registered: Oct-05 | ^ fa sho |
Gold Member Username: camBC Canada Post Number: 1921 Registered: Nov-06 | I'd build something other than the regular bass reflex. |
Gold Member Username: Skibum12189Cleveland Post Number: 2610 Registered: Mar-06 | any box size suggestions?? including tuning, etc... |
Gold Member Username: Skibum12189Cleveland Post Number: 2614 Registered: Mar-06 | bump. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 953 Registered: May-07 | I envy you! bump... i wanna know too |
Silver Member Username: MateoPost Number: 276 Registered: Oct-05 | im building a t-line and horn (in some ways is a 6th order) for my 15" Titanium...if you want i can email them to you |
Gold Member Username: JakeyplaysbassClarion Hert... Post Number: 2400 Registered: Jul-05 | Call audiopulse/TC they know way more about there subs than we do... I mean they do make them afterall Cal. |
Gold Member Username: Skibum12189Cleveland Post Number: 2616 Registered: Mar-06 | Sh!t should I go ported or sealed?????? I talked to TC and they suggest 3.0 ft^3 with a Tuning Fq of 29 hz Port area of 25 in^2 and Port Length of 18 inches..... haha, umm i basically know nothing about ported boxes, so wtf does all this mean, i just wanna build a ported box optimized for SQL with sub up and a slot port back |
Gold Member Username: Skibum12189Cleveland Post Number: 2617 Registered: Mar-06 | http://web.archive.org/web/20070224172836/http://www.tcsounds.com/tc3000.htm#diy |
Gold Member Username: Skibum12189Cleveland Post Number: 2619 Registered: Mar-06 | help me please |
Silver Member Username: MateoPost Number: 280 Registered: Oct-05 | im guessing you dont want the plans for my t-line or horn? |
