New member Username: Confusion
Post Number: 1 Registered: Feb-08
Posted on Does anyone know where I can find updated sat and channel files for viewsat xtreme?? |
Silver Member Username: Madflea168
Post Number: 234 Registered: Jan-08
Posted on go to viewsatusa.com |
Post Number: 2 Registered: Feb-08
Posted on I looked all over viewsatusa.com and I can't seem to find those files. Any other suggestions? |
Gold Member Username: Nydas
Post Number: 8102 Registered: Jun-06
Posted on Get Channel Master.
http://www.sharpc.com Do full scan. Load the receiver's channels list into CM. Edit. |
Silver Member Username: Iamdrumming
Post Number: 102 Registered: Aug-06
Posted on Even though I have a Pansat, I found the files on the Viewsat site in less that 5 seconds. Look again under the "Support" tab. |
Post Number: 240 Registered: Jan-08
Posted on duh... [link removed] where exactly are you looking at all over the viewsatusa.com? |
Post Number: 3 Registered: Feb-08
Posted on I was told I needed to install the most recent sat and cha files and just can't find them anywhere. |
