Hello, Nalin, can you help? I flashed with the latest bin my converted pansat, it worked for a day, and this afternoon, I had problems rebooting. The " b-7-5" appear for a while, and diseappear, and so on. What is the problem?
I hear the AV 250 bin is working fine, and the other one Nalin recommended.
If you have done everything, and tried the other bins as well, I don't know what to tell you. Nalin would be the one who would probably know. However, he doesn't appear to be around at the time being.
I'm not understanding by what you mean when you say you can't reboot. Do you mean, once you turn the switch off from the back and on again, it doesn't fully reboot?
If so, just keep trying by trying the back switch off and then on again. Give it plenty of time to do it, as it may take some time. Also, try leaving the switch off a little bit longer before doing it.
Have long have you been testing this particular receiver?
No, I heard only good things. But in the meantime, I wouldn't give up on your pansat. However, I would take a break for now, as it gets hard to think when you've been at it and become frustrated. Also, when Nalin gets on, he can probably be of some assistance to you.
One night, when it was real late, and I was really tired, I was hooking up my pansat and became frustrated when there was no signal. I wasn't thinking clearly at all. After about 5 minutes of trying to figure out what the problem was, I realized I didn't hook the receiver up to the antenna. LOL
Here is a site if you want to check out the viewsat: GlobalWholesalers.biz
