International Channels not working
Username: Reach_honey
Post Number: 84
Folks,
I used to have all 15 International channels working from Echo 1,2(148 angle).
SUddenly today I saw 3 channels were not workig out of all 15. So I did Auto SCan and guess what?
I got only those 3 channels and rest other 12 are gone.
Were channels moved from echo 1,2(148).?
Why am i not getting those channels?
I deleted all channels and rescanned everything but still did not work.
Any help....
Username: Madflea168
Post Number: 242
congratulation,
I believed they have finally moved to 118.
it is time for you to start converting your lnb.
Post Number: 85
But I'm paying legally to DISH for some of internaional channels and those are working with as it is.
so does it mean that I need to add 118 with its settings and rescan it.
If yes then where will i get 118 angle settings
Username: Fwans089
Post Number: 7
Which channels are gone? can you tell us the name of these channels, because i got all channels exept for 3, lbc, mbc and aljazeera
Thanks,
Fadl
Username: Saqeeb9000
Post Number: 2286
none of international channels are gone from 148 dish .. they are where they are..stop spreading rumors...
Username: Tapeman
New York City in-HD, NY
Post Number: 2366
Not just 148
I noticed many hardware behaviour against VS receivers
Well first
DN are doing ECM against Blind scan and EPG
Second
Upon processing a new ECM Auto scan don't work either
Third
Many Double channels causing more problems for VS
It's not going to get easier in the near future
My advice is as a new bin comes out and works well
Re-do your installation and never do factory default again
For now just enter each TP one at a time
But by tomorrow 2/15/08 another ECM on it's way anyway
Post Number: 2291
don't worry king is just scaring you...
that his job..
Username: Tapeman
Post Number: 2368
I'm telling the truth and Sada yo know nothing about hardware
Post Number: 2294
""It's not going to get easier in the near future ""
i am just saying ... king you are scaring people...
