hi Anik F3 118.w I bought LNB DGL--1189aaas LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally I did auto san and blind scanmany many times. but it stoped in the middle. some time 70% and some time 35% finally i got 80 channels.
can some one guide us? how can i setup 118.7W. Thank you
hi Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally I did auto san and blind scanmany many times. but it stoped in the middle. some time 70% and some time 35% finally i got 80 channels.
Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button Then I got 302 active chanells
Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button Then I got 302 active chanells Thank you lookekhoshshans
Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable The frist time Level was 79% Quality was 15% Frist I did power scan. after that fenished scan it got few channels I dellet ed it. I put freq 12455 and SR 20000 Than i scaned with green button. finally I got 302 channells thank you
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 16 2008 ________________________________________ Enjoy everyone! I keep my word! Why because thats all I have! Have a great weekend.
MINGO><OGNIM Attached Files
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 16 2008.zip (1.66
All, I did not used my Ariza reciever for quite sometime. i just uploaded the latest bin and i have data updating on my TV for quite sometime. I forget how do we fix that ? do we have new keys to put it in ??? any help will be greatly appreciated.
This mini guide will get your Ariza receiver up and running! First you will need the following: - Ariza Receiver (obvious) - a RS232 NULL Modem cable - Computer (WinXP) - STB Downloader (program to download file to receiver) - The CORRECT BIN file for your receiver! Make sure of it! If not sure, ask! While you have your Ariza running (power on and sat connected) reset the unit to factory default. Just go into menu and select Factory Setting, enter the pass g0000 and OK. Now turn off, disconnect everything. Put one end of the RS232 cable into receiver and the other into your computer. Plug in the receiver power cord. Now open STB Downloader program and select which COM port is working for you. Then click BIN File and point to the BIN file, make sure itfs the correct version. Click Download. Wait for it to complete. Do not play with the receiver or any cables. When it says g0000 on the receiver then turn off power, disconnect. Connect back to tv,sat..etcc Turn it on and select language. Installation > Antenna Setup > Select which satellite > Select LNB Type (standard) > Any other setting you wish to change like if you have a DiSEqC switch. > Now EXIT. >> Power Scan > Make sure the settings are correct > Then scan.. Now when the scan is finished, exit all the way to TV. Donft worry if you see a black screen because it is normal, for this you have go into Parental Control > Press gIh and g2004 on your remote. Go down to Key EMU and turn it ON and Autoroll depending on file. Then EXIT. Enjoy tv.
CNX (Conaxsat) Mini/Duo/Trio NOT affected by ECM).
C00LSAT 4000 up on BIN 156 C00LSAT 5000 up on BIN 156 C00LSAT 6000 up on BIN 156 C00LSAT 7000 up on BIN 127
CW600s up on BIN 1.68 CW600p up on BIN 1.73 CW700s up on BIN 1.51 CW800pvr up on BIN 1.51
NEOSAT IPRO/PRO/PRO+ CARDLESS '" BIN 253 NEUSAT LITE/TESSAT/BLUEJAY/NFUSION cardless - using 071227_blue_v113
ALL PANSAT models are up using BIN's from Dec 22, 2007 releases PANSAT 250SM up on BIN 552 PANSAT 2500A up on BIN CS_232T_lightning and CS_232T_lightning PANSAT 2700A up on BIN 227+ and 232 PANSAT 2800 up on BIN 437 and 438 PANSAT 3500A up on BIN 343 - 350 PANSAT 6000 up on BIN 3169 PANSAT 9200 up on BIN 9219 - 9224
SONICVIEW 1000 up on BIN 278 SONICVIEW 4000 up on BIN 181 SONICVIEW 8000 up on BIN 238
VIEWSAT Plat also up on latest BIN from 2/14/08 and from 12-07-07 VIEWSAT Ultra up on BIN from 12-07-07 VIEWSAT Extreme up on BIN from 12-07-07
