Bronze Member Username: SnissarPost Number: 73 Registered: Dec-07 | Sorry name change but someone else came out with jvvh_remote bin so I am putting F7= (Fwank7) for idenification. Bin names should speak for themselves. Fortec-2500-Pantec are for those remote users. 2700 remote is for Pansat 2700 remote users. D/N FIX. Set Default Key and let it A/R. (slow A/R ) Turn A/R OFF (except Key Code) if experiencing rebooting issues. No need to do a factory setting in main menu if your not having problems. Do one if you are experiencing problems. Both bins are clone safe. Jvvh_Fortec-2500-Pantec_250. "Original 2700 Bin Modifyed & Compressed by fwank7" Using "Jvvh" name in bin as a sign of respect to the 2500 to 2700 conversion creator. fwank7!! Jvvh(F7)_2700-Remote_250.zip http://www.sendspace.com/file/5i9le8 Jvvh(F7)_Fortec-2500-Pantec_250.zip http://www.sendspace.com/file/v421q1 |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 138 Registered: Jun-06 | Is it good for clones? |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 139 Registered: Jun-06 | Yes it is message says itself. Sorry |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 141 Registered: Jun-06 | This bin has glitch like few buttons not working on remote. |
Bronze Member Username: WisbangOntario Canada Post Number: 24 Registered: Jun-06 | works fine on my pansat convert have to load the right bin to make the remote work properly |
New member Username: TecnipcsMontreal Post Number: 5 Registered: Sep-07 | The new bin doesn't work is a fact. When is gone be new bins? Ho knows.... DN wins.. again.... |
Gold Member Username: NydasPost Number: 8167 Registered: Jun-06 | I am testing the Saif BIN 250 for converted recievers and it works extremely well with DN. **-- **-- **-- **-- **-- **-- **-- **-- For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest Lothario_250. Jvvh and Saif BINs included. Also available separately in All_250.zip file The All_249-2.zip has all the 249 conversion files separately as well Some jtag files are also included. The full kit is in full_kit250C.zip or later. Download the kit and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file. [link removed] |
