Bronze Member Username: Deptrai_cachonPost Number: 31 Registered: Jan-08 | hi guys.. I have viewsat ultra.. using dn echo 8,10 (110 W) .. and couldn't get any ESPN chanenel or CNN .... I couldn't use echo 7 (119 w) because I was told it blocked by other house. ... ohh one more thing ...most of the channels i got are double or tripples.. how can I fix this problems .. please help me ! thanks |
Silver Member Username: Madflea168Post Number: 258 Registered: Jan-08 | you don't really want to post the same Q twice. https://www.ecoustics.com/electronics/forum/home-video/449492.html |
Gold Member Username: Donnie1973Post Number: 2719 Registered: May-06 | if u get 110 u should be able to get 119. I would be suprised if u couldnt, but i guess it is possible. Maybe u could turn it to get the bev satellites. 82 and 91. What are ur antenna settings? If all u have is 110, i guess there are a few ways to set it up, but If u have a dish pro lnb... in antenna settings set lnb type to dishpro- disecq port to 2. Go to channel edit, delete all channels, rescan 110. |
Silver Member Username: BirdwatcherPost Number: 684 Registered: Jul-06 | i doubt that you are set up just so 110 gets and 119 doesnt. they are to f.cking close together. your aiming wrong. Go to dishpointer.com. if you still cant with that site then your an idiot. |
Silver Member Username: Regio65Monterrey, Nuevo Leon Mexico Post Number: 232 Registered: Sep-06 | DAVIDVANDIESEL YOU FU...WHITE TRASH |
