Gold Member Username: Snarl2004Digital Design 9515, Massive Audi... Post Number: 2166 Registered: Dec-06 | I am looking to buy a 04/05 model xxx motor...thanks |
Bronze Member Username: Imback2500Post Number: 49 Registered: Feb-08 | i have a chevy 350 motor think it will fit u can hook up amps to it stupid phuck |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13820 Registered: Jul-05 | Just buy my brahma..same thing |
Gold Member Username: Dakangofkrunk16Post Number: 1091 Registered: May-07 | Did you cantact RE |
Gold Member Username: Snarl2004Digital Design 9515, Massive Audi... Post Number: 2167 Registered: Dec-06 | but ive already got one xxx motor i jsut need one more so unfortunitly the brahma wont work...i cantacted fi about re cones if thats what you mean... |
Gold Member Username: Dakangofkrunk16Post Number: 1093 Registered: May-07 | or RE audio about Re Cones.. But Fi is run by Scott Atwell so yea... Check on CA.com Chauncey How much for the Brahma.. Got pics what size what is the rating |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13821 Registered: Jul-05 | its the MKII...the best of all the brahma's...and one of the best subs ever.. http://www.caraudio.com/forum/showthread.php?t=291483&page=2 |
Bronze Member Username: Imback2500Post Number: 55 Registered: Feb-08 | i have 2 motors callme do ya have my number? |
Gold Member Username: Dakangofkrunk16Post Number: 1095 Registered: May-07 | i wasn't around for that era on here... but i have heard that it was like Fi cause it was talked baout alot... What is the max watts and RMS.. cause Brahma is out of business 4 now.. but that sub is one a kind now... liek an antique lol |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13822 Registered: Jul-05 | Brahma MKII>all of Fi's subs..and I run BL's now ;) max watts?? a million?? rms is 1600..but it sounds good on as little as 400rms.. |
