Gold Member Username: InsearchofbassPost Number: 7978 Registered: Jun-04 | I need some input for this question https://www.ecoustics.com/electronics/forum/computers/448676.html |
Gold Member Username: Dakangofkrunk16Post Number: 1056 Registered: May-07 | I'm a computer expert, but i don't exactly know what you mean.. You want soemthing that is on a dvd that will restore your computer or you just want to delete all dvds on computer |
Gold Member Username: InsearchofbassPost Number: 7979 Registered: Jun-04 | I want to create a backup of what is on my pc now onto dvd's |
Gold Member Username: InsearchofbassPost Number: 7981 Registered: Jun-04 | an exact image |
Gold Member Username: Dakangofkrunk16Post Number: 1059 Registered: May-07 | ah ok they have programs hold on let me see what i got and what is out there that i know of But it will be alot of dvd's best advice do what i did.. i backup all my things to my ex hard Drive.. was gonna be 90 dvds lol... Mostly cause i have over 400 movies and 50,000 songs Windows Live One care has a back up program... I'm tryin to find others in the process |
Gold Member Username: Dakangofkrunk16Post Number: 1060 Registered: May-07 | IF you have your Windows Cd you can do thishttp://www.microsoft.com/windowsxp/using/setup/learnmore/bott_03july14.mspx |
Gold Member Username: Dakangofkrunk16Post Number: 1061 Registered: May-07 | http://www.download.com/3120-20_4.html?tg=dl-20&qt=backup%20to%20dvd&tag=srch There are some programs here too.. Nero also has the ability to back up your files and hole computer... If you don't want to buy it let me know i can send you a free copy that has been cracked( i mean i paid for cause free things is wrong ) hope gov't aint in this thread |
Gold Member Username: InsearchofbassPost Number: 7983 Registered: Jun-04 | well what I really want is a way to reinstall vista without buying the disks from HP ....I can cover the rest |
Gold Member Username: InsearchofbassPost Number: 7984 Registered: Jun-04 | thanks but I do things legit ...I own nero if it isnt on this pc already |
Gold Member Username: InsearchofbassPost Number: 7986 Registered: Jun-04 | ahh I might as well order the recovery disks its easier |
Gold Member Username: Dakangofkrunk16Post Number: 1062 Registered: May-07 | how much is it.. usually there free from the company.. well i know dells recovery disk are free.. When they had them |
Gold Member Username: InsearchofbassPost Number: 7987 Registered: Jun-04 | I dont know let me check....they have a back up feature that stores to the hard drive so no backup cd comes with it... I dont like that idea I want a hard copy |
Gold Member Username: InsearchofbassPost Number: 7988 Registered: Jun-04 | opps you can make one to a disk from the recovery program built into the pc ...it does what I need ....recovers back to original factory condition not the current installation but I can take care of the rest...reinstalling vista is my main concern |
Gold Member Username: Dakangofkrunk16Post Number: 1065 Registered: May-07 | ok so your good then.. and i helped not one bit lol |
Gold Member Username: InsearchofbassPost Number: 7991 Registered: Jun-04 | yes you did...thanks for your help |
Gold Member Username: Dakangofkrunk16Post Number: 1066 Registered: May-07 | orry for such a delay i was at gym... it will work on any hard drive |
Gold Member Username: InsearchofbassPost Number: 7993 Registered: Jun-04 | cool |
