Reciever refuses to scan nimiq
Username: Jaye50
Post Number: 77
converted fortec flat out refuses to scan nimiq 1.3 or nimiq 2......will scan for about 20 secs and then restart itself....tried blind scan....will scan until it starts to list the tp's and do the same thing....restart itself.....????
Username: Inon
Post Number: 10
hi jaye i had the same problem so i renamed it (edit sat) and it worked fine
Username: Jaye50
Post Number: 78
i'll give it a try...thanx....
Username: Jaye50
Post Number: 79
so far.....so good.....looks like that did it....much thanx man.....much thanx.....
Username: Newbiehater
Quebec
Post Number: 64
And blacklist thinks he can do a full emu bin ! LMAO
He can't even make one non bug ridden bin.
Username: Wisbang
Ontario Canada
Post Number: 21
can someone tell me what it means to rename sat and how to do it i have the same problem with nimiq thanks
Username: Jowhar
Post Number: 259
Lizzie what receiver do you have.
Username: Satgrl
Dil Mei DarD a Jaga ...
Post Number: 1468
lizzie edit the sat from menu...it just means changing the name i dont see why someone would wanna do it! do a facotry defualt and maybe u can try blind scanning on nimiq it will work
Username: Jowhar
Post Number: 260
satgrl I try to blin scan and the receiver will shot off and now since b3v is down I just quit.
Username: Satgrl
Post Number: 1473
umm its suppose to shut down it has to reboot itself
Quebec
Post Number: 83
It's a glich in the last dozen or so blacklist bins,keep retrying ,have adozen times or so ,it'll finnally scan nimiq.
BL always does the very minimal work ,never corrects minor gliches, fixes one glich he causes another . Has always been that way, alway's will.
and ppl think he can do full emu. lol
Username: Jowhar
Post Number: 261
Not only one time keep doing that all the time.and what I have is pansat clone 2700
Username: Wisbang
Ontario Canada
Post Number: 22
i have a pansat 2500a converted to a 2700
Username: Inon
Post Number: 11
menu --> installation --> edit tp/sat --> choose Nimig 1.3 --> press OK --> choose rename --> change to 91W --> press ok --> exit and do a blind scan
Username: Wisbang
Ontario Canada
Post Number: 23
okay thanks ill try it, they say now that bev is gone also but ill know for when it comes back
thanks
FTAwhew what a stink
Post Number: 95
