Whats a good 12?
Username: Rockfordman2149
Champaign, Illinois US
Post Number: 89
Like the title says. I want to know so I can get some for this car wars this year. My budget is 1300 for the subs.
Username: Nickyp0219
Post Number: 628
you want 2 12's? what are you going to power it with?
Post Number: 91
As many as I can get for 1300.
Username: Surferdude9371
Im BTL Bumpin
Post Number: 633
want spl sq or sql?
Post Number: 92
spl
Post Number: 630
shouldnt you be saving for your 4 18" BTLs?
lol jk, but how much are you going to spend on an amp or do you already have one
Post Number: 93
depends on what i spend on the subs
Post Number: 94
"shouldnt you be saving for your 4 18" BTLs?"
lol i figured i have plenty of time to save for those and by the time if have the money theyll have alot better subs
Post Number: 631
i thought you have a few p1s?
Post Number: 95
yea 4. but im selling em this summer and spending that money on amps
Username: Th3pwn3r
Post Number:...
Post Number: 6831
Who is holding this "Car Wars" event? I might have to go up there and see how it is.
Post Number: 96
Good Vibez. It's a long way away I'm just getting ready early.
Post Number: 97
So what's a good 12" spl woofer?
Post Number: 633
kicker L7
i hate recommending it, but for what he wants i think its his best choice..correct me if im wrong
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5429
a good 12" spl sub i would have to say
t3 tsns
dd99z
atomic apxx
shocker neo sig
if you really have 1300 dollars to spend you can buy any of these subs...
Post Number: 635
i agree driving, but the most amount of subs w/ the most output potential for the least amount of $ would be the L7 correct?
Post Number: 5431
wrong....L7s are cheap SPL...they are no were near as loud as the subs i mentioned...of course you can make more subs get louder then 1 sub...but then youll be competing against ppl that have 5 good spl subs...
his best bet is to have two twelves..and compete with those...itll be loud as fawk either way...its all about install..Alan dante proved that
Username: Insearchofbass
Post Number: 7947
I got one in mind for you but let me look
Username: Th3pwn3r
Post Number:...
Post Number: 6833
"a good 12" spl sub i would have to say
t3 tsns
dd99z
atomic apxx
shocker neo sig
if you really have 1300 dollars to spend you can buy any of these subs..."
WRONG. You can't get a 99z for 1300 bucks. Especially not a 12.
Post Number: 99
ok
Post Number: 636
i stand corrected
Post Number: 100
"WRONG. You can't get a 99z for 1300 bucks. Especially not a 12."
damn how much are they??
Post Number: 7948
JUGGERNAUT 12
Voice Coil (Ohms) 2 x 2
Fs (Hz.) 42
Vas (Liters) 27.6
Qts .45 0.43
SPL (1W/1M) 88db
Power (Wrms) 1500
Mounting Depth (inches) 7 1/4
Hole Diameter(inches) 11 3/16
Speaker Displacement (cu ft.) .35
Post Number: 7949
I have others in mind but im looking out for a realistic charging system... how much alternator and batteries are you going with
Post Number: 637
how about an xxx?
Post Number: 101
"how much alternator and batteries are you going with"
im sure lol. its a stock 1996 ford explorer
Post Number: 7952
what engine and model explorer
Username: Mj23dynasty
They Love 2 Hate Me, Most Hated a... USA
Post Number: 1392
Go with tht LMS 5200 or ultra whatever its called that reece is raving about. Idk anything about them but every1 says they r the sh1t!
Username: Talon01
Team revolution , Pa Usa
Post Number: 835
with that vehicle i know you can do a 147.0 or close to it with a aq hdc312 on 1500w. dj from aq tested one in that veh. sub up port to the pass. side
Post Number: 7967
you know i was thinking of the hdc3 12 too for the money that would be a good idea since you probably cant touch a juggernaut for anywhere near its price and you already have a good idea what the hdc 12 will do in your vehicle...if your serious about this get yourself a meter...also your stock alt size is probably 95 amps but could be as high as 130 amps...If you want a sub that will work well with your stock alternator do a audioque sd 2.5 12...we hit a 145.3 db on the termlab with one on 750 rms in a burp box and im pretty sure with a new box we can hit more...if your not going to upgrade your alternator you wont be able to take full advantage of the hdc312 and might struggle to beat the 2.5 12 without causing voltage issues from what ive seen out of my bro's once stock 130 amp alt.
