ProgDVB, Mytheatre, & DVBviewer Question
Username: Cybermaster
Post Number: 122
Just wanna know which one of these is the best one and if they support Twinhan PCI VP 1020A, and TWINHAN USB STARBOX RECEIVER. any info be great. Thanks.
Username: Vittu
Post Number: 152
I use DVB Dream and MyTheatre. DVB Dream is freeware and also support mpeg4. In your case, I would recommend mytheatre since you are not going HD
Username: Tstdrivr
U.S.A.
Post Number: 37
You can watch HD with mytheatre I'm running 3.37 with a twinhan 102g and watch bev HD on nimiq2
Username: Vittu
Post Number: 157
what about DishN HD?? specially MPEG4?
Username: Tstdrivr
U.S.A.
Post Number: 38
http://www.genpix-electronics.com/index.php?act=viewProd&productId=3
this is the only way right now to get dishHD on your computer. twinhan, hauppauge, ect. they don't make a card capable of 8psk. mytheatre does support 8psk but your right it doesn't support mpeg4 (yet). Dvb dream does have mpeg4 but I'm not sure if it supports 8psk I'm not very familiar with dream.
Username: Tstdrivr
U.S.A.
Post Number: 39
Just installed dream and YES it does support 8psk so with the skywalker-1 you will get full support for dikHD
