DEI Hornet Alarm / Remote start
Username: Hoppin_poop
Got a quick question... I have installed many DEI alarms/keyless entry systems in the past without any problems. However, this unit seems to send out a constant ground signal on the blue lock/unlock wire. If my memory serves me right, both green and blue lock/unlock wires should not have a positive of negative signal until the keypad is pressed. is this correct? or have things changed?
