Amp for two cvr 12s
Username: Justin_13
what is the best amp for two Kicker Comp-CVR 12" Subwoofers:
Specifications:
Injection-molded
Double-stitched, foam-ribbed rubber surround
Frequency response: 25-500 Hz
Power handling: 50-400 watts RMS
Peak power: 800 watts
Impedance: 2 or 4 Ohms DVC
Dual Voice Coil
Sensitivity: 86.7 dB
Top-mount depth: 6-3/16"
Sealed box volume: 1.0-4.6 cu. ft.
Ported box volume: 1.75-2.25 cu. ft.
Username: Bonhamd
Northern, Michigan USA
Post Number: 234
budget?
Username: N2audio
Lawrence, Ks USA
Post Number: 1477
and dvc 2 or 4?
Username: Justin_13
somewhere around 300...i was thinkin about the kicker ZX 750 but i didnt kno if that would push them
Username: Somedonniedude
Illinois United States
Post Number: 932
A zx750.1 would push them nicly, as long as they are Dual 2 ohm subs.
Username: Justin_13
i think they are 4 ohms. why cant they be 4
Username: Schinner
Post Number: 66
i have a zx 750.1 birthsheet has it pushing much more than 750 rms....around 850-900rms if i remember correctly, it should push those 12 cvrs and yes if they are the dvc 4 ohms you wont be able to wire them to a 2 ohm load....you wont be able to use the full power of the amp.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13809
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Justin_13
what do i get if they are 4 ohms then
Username: Bonhamd
Post Number: 258
an amp that will do around 800-1000rms into 1 ohm.
you can probably get this for a good price...
http://cgi.ebay.com/ebaymotors/Diamond-D3-800-1-In-original-box-Class-D-JL-D6-D9 _W0QQcmdZViewItemQQcategoryZ38638QQihZ019QQitemZ290205134205QQrdZ1QQsspagenameZW DVW
or sonic electronix has it for $240. but there are plenty of amps you can get in the price range you have posted. I am sure these guys can come up with a good idea for you.
Username: Justin_13
the manual says it can be 2 or 4
Username: •cam•
BC Canada
Post Number: 1920
That's because you can get them in either dual 4 ohm coils or dual 2 ohm coils. We need to know which coils you have.
Username: Drant19
DUB-C, TX
Post Number: 340
if you have ONE dual4ohm sub, it can be wired to 2, 4, or 8ohms. but since u have TWO dual4ohm subs you can wire them to 1ohm and 4ohm. its easier to get more power at 1ohm, so u want to look for an amp that does 800-1000rms at 1ohm
Username: Justin_13
so the 1 ohm works with 4 ohms
Username: Bonhamd
Post Number: 271
(2)dual 4 ohm subs can be wired to 1 ohm.
Get an amp that supplies 800-1000 watts RMS into 1 ohm.
Username: Justin_13
Post Number: 8
alright thanks
Username: Justin_13
Post Number: 12
so since i hav 2 of them they cant be wired to a 2 ohm load because the manual says one sub would be able to...
Username: Ctmike
Ct.
Post Number: 5859
yes, one sub can be wired to 2ohm. a pair of dual 4ohm subs though can't. as explained already. go to www.jlaudio.com, they have a wiring wizard for you to use.
just get an amp that'll do 800-1000wrms at 1ohm and wire the pair to 1ohm and you'll be set. personally, i'd get a sundown sae1000d. $300 shipped from dealer, great little amp, nice warranty and customer service. can't go wrong with it. order here if interested, www.kluvkustoms.com. very nice customer service there and fast shipping.
Username: Bonhamd
Post Number: 297
here-
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
those are your options
