How do I load bins to my satelite?
Username: Jose420
Sacramento, California United states
Post Number: 10
What program do I use to download the new bins to my Viewsat Extreme Dish Network box?
Username: Guanajuatos_best
Post Number: 182
U GOT LOADER 2?
GOT BIN?
HAVE DONE SOME PREVIOUS READING?
Username: Jwl1
Post Number: 135
Google search it or look around. I don't know if they might have the info at crazyfta (.com), but you might want to have a look over there.
One of the sites will have it or the info of where you can get it.
Username: Jwl1
Post Number: 136
Jose,
I had a look at the place I mentioned, what you need in there. In the future, it's good to have all of that first before you even start.
Username: Jose420
Post Number: 11
I got the loader now, Im going to check out that site, thanks!
Username: Jwl1
Post Number: 140
Your welcomed. Good luck.
Username: Jose420
Post Number: 12
Ok I got the loader 2, I downloaded the new bin I think and while downloading as its about to finish it say's failed, I dont know why or if Im downloading the wrong bin?
Username: Birdwatcher
Post Number: 674
Upload Like this
Username: Jwl1
Post Number: 142
There should be instructions at the site I mentioned. If not, you can find them some where. I'm told the most common mistake is turning the receiver off before the upload is finished.
Therefore, start from the beginning, and don't do anything until it's finished. Then turn it off.
You'd need to give more of a description of what happened.
Username: Jwl1
Post Number: 143
Forgot to mention you can also check what bin is on it (the receiver) by going into the system.
However, if I recall, isn't this a new system?
Username: Jose420
Post Number: 13
yeah I read all the info but their is something Im still doing wrong, I think cause on the loader program my new bin file is in the undefined file section, So Im thinking it should be under the main software section so Im trying to figure out how to move it there so I think thats my problem.
Username: Jwl1
Post Number: 144
Did you unzip the bin? Best to make a folder and put what you need in it.
Username: Jose420
Post Number: 14
Yeah I finally got it, up and working! Thanks alot Joe!
Username: Jwl1
Post Number: 145
Jose,
I looked to see if there were any instuctions with the loader--and there are. Are these the instructions you are using? If no, use them. It's step by step..and basic procedure.
If you are using them make sure to scroll down where it says to wait for it to reboot.
What cable are you using?
Username: Jose420
Post Number: 15
yeah Im all set I got it working, Thanks alot!
