Pansat 3500 no light
Username: Ez2bme
Dallas, Tx Dallas
hello i was downloading a bin file for my pansat and all of sudden it freezed and my pansat turned off and every time i try to turn it on the LED light wont show up. i am very new to this so can anyone tell me how i can fix this...Thanks
Username: Ndn3
Post Number: 138
connect the null cable (used to download) to the fta and other end to computer and download the latest bin file.
it should work. I had the similar situation, and the above worked.
Username: Ez2bme
Dallas, Tx Dallas
it doesnt seem to be working when i click download it stays at 0 percent i turned on the pansat but still no light. i also have a memory card slot in my computer that i use to download the bin files but that doesnt work.
Username: Dimwitt
Post Number: 407
go to the site you get your files at , look for jtag 3500 instructions and files.
you will also need to buy or make a jtag cable.
